1991 eclipse Gsx Vehicle Profile & Build Thread
1995 Galant es with 91 gsx full swap.
1995 Galant Es 4g63t awd swap
Ownership Status
Currently Own
Vehicle
1991 eclipse Gsx
Build Type
  1. Rally
F.I.C 650CC injectors
Walbro 255 with Adj FPR
Holset H1C
F.M.I.C short ran.
Fluidyne Radiator
Plx dm6 wideband
4 bar omni gm map and gm iat from Extremepsi.
1G BLACK TOP CAS
91 gsx ecu
FULL 3" with High flow cat exhaust.
Mods-Engine
Machined head- motor was rebuilt still stock.
Mods-EMS & Logging
Moates Ostrich 2.0 using tuner pro
Mods-Drivetrain
Fidenza flywheel- act 2600 clutch
D2 Rally coilovers- Custom camber plates in front- Front upper strut tower bar. - Modified front subframe using 4140 box steel with solid front motor mount.
Parts Wishlist
Aluminum fuel cell- built 6 bolt- new rims
Background
Car started as a family project. Took 6 months to complete. Now has a 8g galant front with evo 8 wing
Comments
There are no comments to display.
4G63t Swapped
SinInkster
More in 4G63t Swapped
More from SinInkster
Share this vehicle
