ecliperacen88's Eclipse GSX
- Year
- 1995
- Model/Trim
- Mitsubishi Eclipse GSX
- Mods-Bolt-on
- Ball bearing FP3052 turbo,Tail 44mm race external wastegate abd v-band dump tube,3" mandrel bend and catback exhaust with 3" down pipe, slow boy racing ported 8cm2 manifold, slow boy racing 2G large race FMIC 28x14x4 and 2.5 i/c piping, greddy BOV, dejon tool sheet metal 6" runner intake manifold polished, 1G 60mm throttle,
- Mods-Engine
- 2.0 1991 4g63 6bolt bottom end, ross racing pistons, pauter rods, .020 bore, cylinder head 1991 1G completely ported runners,1mm ferea swirl polished valves, dual valve springs, titanium retainers, seat locators, bronze guides, SP2 comp camshafts
- Mods-EMS & Logging
- dsmlink version 2, 1995 E-prompt ecu, MAF translator versiom 2, C2DI from AEM,autometer oil pressure guage, boost guage and vac guage, A/f ratio meter, EGT guage, oil temp guage, blitz srec R dual selenoid boost control, dyno jet wide band, denso 720cc injectors, 255LPHalbro fuel pump,
- Mods-Drivetrain
- ACT 2600, balanced with flywheel,viscous coupling eliminator, B&M short throw shifter
- Mods-Handling
- skunkworks fully adjustable coilovers, tokico illumina adjusable shocks,front and rear sway bar and strut tower bar,Enkie rims 18", yokohama parada tires, powerslot front and rear zink coated slotted rotors, braided brake lines
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
