1997 Mitsubishi Eclipse GST Vehicle Profile & Build Thread
chong030672's Eclipse GST
Aluminum Ralli-Art Oil Cap,
1.3 kg/cm2 Ralli-Art Radiator Cap,
Mitsuboshi bolt on Aluminum Radiator,
Gate blue silicone upper & lower radiator hoses,
Braided Hose Kit,
Performance 15 rows 13" X 5.5" x 2" Oil Cooler,
OBX Coolant Aluminum Reservoir Tank,
OBX Power Steering Fluid Reservoir Tank,
OBX 4G63 turbocharger header,
OBX fuel rail,
RS High Performance Blow off valve,
RS 30" x 11" x 3" Front Intercooler,
DSM EVO III 16g turbocharger,
OEM 3 inches cathalizer,
Super Turbo 3 inches exhaust muffler,
Custom 3 inches exhaust system,
Custom 3 inch aluminum inlet pipe system,
Blue silicone Spark Plug Wires,
Hayame Blue Spark Plug Wires Cover,
Hayame Blue Fuse Box Cover,
Front Angel Eyes Black Head Lamps,
Rear Euro Black Tail Lamps (complete set)
Mods-Engine
Stock 7 bolts 4G63T
Mods-EMS & Logging
1000 cc RC injectors,
AEM Engine Management System 30-1310
AEM 3.5bar MAP Sensor - 30-2130-50
AEM Intake Air Temperature Sensor - 30-2010
AEM Boost Control Solenoid - 30-2400
Mods-Drivetrain
ACT Street Clutch kit,
Phrotaene Motor Mounts,
TENZO-R Front tower strut bar,
TENZO-R Rear tower strut bar
Black W/ Machined LIP 17" x 7" ENKEI Series No. 420 RZ-5,
245/45-17 Hankook Ventus HRII H405 Tires,
Tein Sport Tech Lowering Spring,
22mm Chromemoly Front Sway Bar,
18 mm Chromemoly Rear sway Bar
Parts Wishlist
Front Lower Tie Bar & Rear Lower Tie Bar,
2 Points Front & Rear Under Brace Bar
Willwood Front Big Brake Kit,
Drilled & Sloated Rear Brake Rotors,
Aluminum Intake Manifold,
1G Eclipse 60mm throtle body,
Ported Cylinder Head with Brian Crower 1mm oversize valves & racing springs,
2.4 Strocker
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Fuel Used : Pump gas
Tires : Street Radials
0.0 lb/ft
2G DSM
chong030672
More in 2G DSM
Share this vehicle
