2g DSM build
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GST
- Drivetrain
- FWD
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Precision Turbo 6266 Ball Bearing Turbo
MAP 304SS Tubular T3 Exhaust Manifold Kit
MAP Turbo to Manifold Stud and Nut Kit
JM Fabrication Intake Manifold
S90 Billit Alluminum throttle body 70mm
Turbo Smart Comp Gate 40 External Waste Gate
MAP Dump Tube
AEM 340LP E-85 Compatible Fuel Pump
STM Tuned Complete Fuel Line Kit for e-85
APE E-85 Flex Fuel Sensor Kit to auto adjust based on e-85 content
Deatshwerks Fuel Pump Hardware Kit
Gates Racing Belt
Greedy BOV
Fuel Injector Clinic 1200cc High Z Injectors
MAP AFPR Kit with Fuel Lab Fuel Regulator
Fuel Injector Clinic Resistor Delete
VRSF Super Short Route Intercooler Kit
AEM High Performance Fuel Rail
AEM Water/Meth Fail Safe Device
AEM Tru Boost Controller
AEM X Series Oil Pressure Gauge
AEM Wideband UEGO AFR Sensor
HKS Exhaust
- Mods-Engine
- Manley Forged Crankshaft
Manley H beams
Wiseco .020 Over Pistons
ACL Main and Rod Bearings
ARP Head Studs
Cometic Multi Layer steel head gasket
- Mods-EMS & Logging
- AEM EMS Series 2 Stand Alone ECU
Dyno Tuned by Dardan Tuned
- Mods-Drivetrain
- CCL Comp Clutch Twin Disk Ceramic Clutch Kit (1000whp)
Kaaz Limited Slip Differntial
- Mods-Handling
- Volk Te37sl Triple black wrapped in R888R
Megan Racing Rear Trailing Control Arms
Megan Racing Rear Toe Control Arms
Megan Racing Front Upper Strut Bar
Megan Racing Rear Lower Tie Bar
Rear 6 Point brace
K-Sport Coilovers
Cross Drilled and slotted brakes
- Dyno HP
- 404 whp
- Dyno TQ
- 287 lb/ft
- Dyno Type
- Dynapack
- Dyno Session Details
- 96 degrees during testing
