1. Join the Community!
Street Build 2g DSM build
Year:
1998
Model/Trim:
Mitsubishi Eclipse GST
  • Drivetrain:
    FWD
    Transmission Type:
    Build Type:
    • Street
    Mods-Bolt-on:
    Precision Turbo 6266 Ball Bearing Turbo
    MAP 304SS Tubular T3 Exhaust Manifold Kit
    MAP Turbo to Manifold Stud and Nut Kit
    JM Fabrication Intake Manifold
    S90 Billit Alluminum throttle body 70mm
    Turbo Smart Comp Gate 40 External Waste Gate
    MAP Dump Tube
    AEM 340LP E-85 Compatible Fuel Pump
    STM Tuned Complete Fuel Line Kit for e-85
    APE E-85 Flex Fuel Sensor Kit to auto adjust based on e-85 content
    Deatshwerks Fuel Pump Hardware Kit
    Gates Racing Belt
    Greedy BOV
    Fuel Injector Clinic 1200cc High Z Injectors
    MAP AFPR Kit with Fuel Lab Fuel Regulator
    Fuel Injector Clinic Resistor Delete
    VRSF Super Short Route Intercooler Kit
    AEM High Performance Fuel Rail
    AEM Water/Meth Fail Safe Device
    AEM Tru Boost Controller
    AEM X Series Oil Pressure Gauge
    AEM Wideband UEGO AFR Sensor
    HKS Exhaust
    Mods-Engine:
    Manley Forged Crankshaft
    Manley H beams
    Wiseco .020 Over Pistons
    ACL Main and Rod Bearings
    ARP Head Studs
    Cometic Multi Layer steel head gasket
    Mods-EMS & Logging:
    AEM EMS Series 2 Stand Alone ECU
    Dyno Tuned by Dardan Tuned
    Mods-Drivetrain:
    CCL Comp Clutch Twin Disk Ceramic Clutch Kit (1000whp)
    Kaaz Limited Slip Differntial
    Mods-Handling:
    Volk Te37sl Triple black wrapped in R888R
    Megan Racing Rear Trailing Control Arms
    Megan Racing Rear Toe Control Arms
    Megan Racing Front Upper Strut Bar
    Megan Racing Rear Lower Tie Bar
    Rear 6 Point brace
    K-Sport Coilovers
    Cross Drilled and slotted brakes
  • Dyno HP:
    404 bhp
    Dyno TQ:
    287 lb/ft
    Dyno Type:
    Dynapack
    Dyno Session Details:
    96 degrees during testing
Share this Item
Comments
  1. Thomas Mason
    How much are you looking to get out of it ? Thanks
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
