1998 Mitsubishi Eclipse GST Vehicle Profile & Build Thread
Street Build
1998 GS-T | 2017-Present | (Cheston Engineering)
Ownership Status
Currently Own
Drivetrain
FWD
Build Type
  1. Street
Turbo Setup:
Precision 6466 Gen2
T4 Divided 1.15 A/R Turbine Housing
Topmount T4 Divided Turbo Manifold
Twin 38mm TIAL Wastegates
Fuel Setup:
FIC 2200cc Injectors
Magnus 1000HP Billet Fuel Rail
Fuel Pump Options
- 2x Walbro 450
OR
- Walbro 525
Mods-Engine
7-Bolt Block (Early 1995 Non-Split Thrust):
Bored 0.020" Over (85.5mm)
Wiseco Sport Compact Pistons - 9.0:1
Eagle H-Beam Connecting Rods
GSC Power-Division Race Balance Shaft
ACL Race Tri-Metal Main Bearings
ACL Race Tri-Metal Rod Bearings
ARP Head Studs
ARP Main Studs
Orbit Performance Oil Pump
6-Bolt Head:
BC Stage 3 276°/276° Camshafts
Ferrea Valves
Beehive Springs/Retainers
3G No-Tick Lifters
Kiggly HLA Pressure Regulator
AEM Adjustable Cam Gears
ARP Cam Bolts
Mods-EMS & Logging
DSMLink v3
Mods-Drivetrain
LSD RipGrip Insert
ACT StreetLite Flywheel
XTD 6-Puck Sprung Clutch
ARP Flywheel Bolts
Megan Racing Lowering Springs (2" Drop)
KYB AGX Adjustable Struts
Torque Solution Solid Aluminum Front Subframe Bushings
Prothane Complete Suspension Bushing Kit
  • Like
Reactions: 19Eclipse90
