Skooma
- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GST
- Turbo Type
- 20g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- Engine:
Hahn RaceCraft Super 20G Turbo Upgrade Kit / TU-4215 Install Kit
Hahn RaceCraft Super Turbo O2 Housing - Type I
Hahn RaceCraft T/E Front Mount Intercooler w/ IC Pipes
Forced Performance DSM Race Manifold
A'PEXi N1 Downpipe & Exhaust Combo
HKS SSQV Blow Off Valve
Greddy Upper Intercooler Pipes w/ HKS Flange
Injen IS Series Intake w/ BOV Recirculation
A'PEXi Power Intake
HKS Adjustable Cam Gears
HKS Fine Tune Timing Belt
Greddy Oil Filter Block Adapter
Unorthodox Racing: Ultra SS Lightened Underdrive Pulley Set
ATI Super Harmonic Damper
Fluidyne 38mm Radiator
Aluminum ultralight fans
- Mods-Engine
- Manley Performace Forged "Race Series" Crankshaft / 7-Bolt (88mm)
Eagle Rods
Wiseco Pistons / 7-Bolt - .020" Over / 9.0:1 Compression
Clevite 77 Main Bearing Set / Standard
ACL Race "Tri-Metal" Rod Bearing Set / Std w/ Addtnl .001" Oil Clearance
Cometic Head Gasket / 7-Bolt - .020" Over (86 mm)
ARP Main Studs
Balance Shaft Eliminator Kit
Forced Performance / Comp Cam2 Camshafts (I/E)
Crower Valve Spring & TI Retainers
Crower Stainless Steel valves
Topline Valve Seals
LASH ADJUSTERS LIfters (3mm)
ARP Head Studs
Walbro 255 lph HP
FIC 850cc Ball-Style Fuel Injectors
Aeromotive A1000 Fuel Pressure Regulator
- Mods-EMS & Logging
- A'PEXi S-AFCII Super AirFlow Converter (401-A913)
PLX WideBand A/F
Autometer Gauges (Boost, Volt, EGR, Oil Press & Temp, Wideband A/F)
- Mods-Drivetrain
- ACT Heavy-Duty 2100 Street Clutch Kit
ACT Sprung 6-Puck Race Disk
ACT Release Bearing
ACT StreetLite Flywheel
Clutch Master Cylinder Assemblyou
B & M Short Throw Shifter
- Mods-Handling
- Goodridge Stainless Steel Brake Lines
Hawk HPS Brake Pads / Front & Rear
Prothane Motor Mount Inserts
MOMO CORSE Pilota 2 Steering Wheel
MOMO Steering Wheel Hub Adapter
- Parts Wishlist
- IN GARAGE, NOT INSTALLED... YET:
AEM High Volume Fuel Rail
FIC 1000cc Fuel Injectors
Fuelab 818 Series In-Line Fuel Filter
Magnus Heat Barrier Intake Manifold Gasket
Magnus Sheet Metal Intake Manifold w/ Velocity Stack (Standard)
Greddy Full Auto Turbo Timer
Greddy PRofec B-Spec II Boost Controller
Greddy Oil Cooler Kit
Tokico Illumina Suspension Kit / 1.5" Drop
Energy Suspension Hyper-Flex Master Bushing Set
- Background
- Passed down from father recently, literally blew her up in 2007... many years spent rebuilding her... now she purrs and roars!!! Very proud to have this car handed down from pop... I am one of six so, yeah...im his favorite!!!
Daily driver/sleeper... don't look over at me like you want a piece... ill give you the whole pie... then at the next light act like you weren't trying... lmao
