1997 eclipse 420a Turbo
- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse N/T
- Turbo Type
- 16g
- Transmission Type
- Manual
- Build Type
- Street
- Mods-Bolt-on
- hahns turbo kit, greddy rs bov, begi? sfmu, 255lph fuel pump, bigger injectors unsure of size. wet and dry shot nitrous set up. missinglink
- Mods-Engine
- forged pistons, rods, stock upper to my knowledge
- Mods-EMS & Logging
- autometer gauges: egt, boost, fuel pressure, oil pressure, nitrous, tach, narrow band A/F. MSD Dis-2 Programmable with map sensor retard .
- Mods-Drivetrain
- stage 2 transmission, short shifter
- Mods-Handling
- kyb AGX adjustable coil overs with skunk2 sleeves and springs all the way around, aem front cross drilled slotted rotors, rear drilled/slotted rotors, stainless braided brake lines. 19in hd custom wheels with 245/35/19 rubber.
- Background
- Well as for background, I had bought the car pretty much as it is right now with the exception that it didn't run. Turns out it had a ground cable loose, put a knew IAC and IAT connector on it and low and behold it ran with no check engine lights. So basically i'm in the process of cleaning up all of the wiring of the previous owners and making everything look and operate a little better. Future plans for this car is to get everything on it working reliably and at its full potential, then hopefully sell it and pass it on for somebody to enjoy and have a nice reliable turbo DSM.
