1998 Mitsubishi Eclipse GST Vehicle Profile & Build Thread
Dmartinez316's Eclipse GST
MHI 20g at 20 psi, t-netics cast exhaust manifold in a heat blanket, pte 39w wastegate, 1g intake manifold (egr deleted), 64mm throttle body rebuilt and modified by TBrebuild.com, ebay FMIC kit, greddy type s BOV, no name intake with k&n cone filter, walbro 255 rewired, delphi 1000k injectors, fuel lab 515 AFPR, custom coil on plug ignition with NGK 7s, aluminum radiator with 12" mishimoto fan and 13" spal pusher fan, 3" megan downpipe and 3" SRS cat back exhaust (cat deleted).
Mods-Engine
1g rebuilt cylinder head with 5 angle valve job, ferrera titanium valves and springs, intake vallves are 1mm oversixed, WEB 547/546 cams with new seals, top line revised hydraulic lash adjusters, ARP head studs and cometic MLS head gasket. Balance shaft eliminated, ridge honed, decked and hot tanked.
Mods-EMS & Logging
dsmlink v3 lite, AEM UEGO wideband, phantom boost gauge and water temp gauge in celsius.
Mods-Drivetrain
XDR 6 puck clutch with fidanza lightened flywheel, and red line MT90 fluid.
1/8 Mile E/T
0.000
1/8 Mile MPH
0.000
Timeslip Details
Fuel Used : Pump gas
0.0 lb/ft
