Red 98 Gsx's Eclipse GSX
- Year
- 1998
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Manual
- Mods-Bolt-on
- Injen Air Filter, Custom 4" Intake with HKS Recirculated Bov
Garrett GT3582 Turbo T4 Compressor and T3 Turbine Housing (Flows 65lbs per min/ 830cfm)
Hallman Manual Boost Controller
Punishment Racing Front Mount Intercooler/ Clean Cut Front Bumper for Flush Fitment
Mishimoto Aluminum Radiater/ Slim Line fan mounted in engine bay and the other mounted infront of the radiater and an a/c condenser in order to provide clearance for the turbo
Rebuilt 1990 DSM N/T Throttle Body (Better Flow)
Evo 3 Intake Manifold
Walbro 255 Fuel Pump
Delphi Low Impedance 1000cc Injectors
HKS 272 Cams
Tubular Manifold T3 Fitment (Ceramic Coated and Header wrapped)
Tail 38mm Wastegate Slim Design Vent to Atmosphere Dump Tube
3" o2 Housing, Downpipe and HKS Hi-Power exhaust
- Mods-Engine
- OEM Composite Head Gasket with ARP L19 Head Studs Torqued to 90 ft/lbs
Intake and Exhaust Manifolds are Port Matched for the Head
Avid Racing Poly Urethane Motor Mounts-CNC Aluminum with inserts
- Mods-EMS & Logging
- HKS Turbo Timer
AEM Fuel Pressure Regulator
Evo 8 MAF w/ Translator for DSM Connection
Currently Tuned on Evoscan
Anti-lag and 2 step set up tuned in
- Mods-Drivetrain
- LSD Rear End
4 Spider Center Differential
ACT 2600 Clutch with Street Disk
- Mods-Handling
- Slotted and Dimpled Rotors
Hawk HP+ Brake Pads
Rims are ADR M-Classics
Tires are Hankook Ventus v4's
Tokico Illumina Struts
Evo 8 Springs and Retainers
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Tires : Street Radials
Sponsored Car : no
- Dyno TQ
- 311.0 lb/ft
- Dyno Type
- Mustang Dyno
- Dyno Session Details
- Fuel Used : Pump gas
Turbo : Full Garrett
Boost : 25
