hookzup's Talon TSi AWD
- Year
- 1997
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Mods-Bolt-on
- Garrett Gt3582 polished#housing hpc coated, jmf fabrications battery kit with odyssey extreme mini battery, hayame chrome complete engine dress up, chrome valve cover, clear powers timing belt cover, chrome/red strut brace bar, avid mounts
- Mods-Engine
- Engine builder: slowboy racing stage 4
Block mods: 6 bolt 2.3 stroker balance shaft eliminated Cometic head gasket
Pistons/compression ratio: wiesco 8.8:1 85.5mm (.020 over)
Rods/crank: Manley I beam clevite main and rod bearings
Camshafts: HKS 280/280 and HKS adjustable cam gears
Valves/springs/retainers: Manley valves, Manley titanium retainers, Manley springs
Cylinder head mods: 6 bolt hot tanked and pressure checked race port and polish, comp plus 5 angle valve job,#
Head/main studs: ARP
Intake manifold: Magnus 1g intake manifold
Fuel injectors: RC 1000cc
Fuel delivery: walbro 255 lph in tank to surge tank to aeromotive a1000 inline fuel pump to aeromotive inline fuel filter to AEM fuel rail to aeromotive adjustable fuel pressure regulator back to surge tank to return to stoc
- Mods-EMS & Logging
- Engine management: AEM ems version 1
Ems tuner: UMS Tuning (Tony) MESA, AZ
- Mods-Drivetrain
- Transmission: Sheptrans stage 4.5 , custom aluminum/polyurethane rear trans mount
Clutch/Flywheel: Exedy 6 puck sprung race clutch ACT lightened flywheel (8 lb)
#Driveshaft shop stage 4 axles#
- Mods-Handling
- k-sport control pro series full coilovers with 36 way adjustable dampening#all around, Wheels: 18 x8 Tenzo dc-6 v2 flat black with red stripe 5x114.3 bolt pattern, aluminum racing lugs, +35 offset#
Tires: Falken 235/45/18 rt-615 drag radials
Brake rotors: Rotora 2 piece cross drilled/slotted 4 piston red calipers front and rear
Brake lines: stainless steel braided
- Parts Wishlist
- Water meth injection, short route I/C piping, fftec in bay area retune both maps, stereo system, possibly a cage
- 1/4 Mile E/T
- 12.100
- 1/4 Mile MPH
- 121.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Timeslip Details
- Track Name : Firebird raceway az
Nitrous : No
Fuel Used : Pump gas
Vehicle Weight : ?
Tires : Drag Radials
Sponsored Car : no
- Dyno TQ
- 401.0 lb/ft
- Dyno Type
- Mustang Dyno
- Dyno Video Link
- Watch Video
- Dyno Shop Name
- Fftec, Hayward ca
- Dyno Session Details
- Nitrous : No Nitrous
Fuel Used : Race gas
Turbo : Full Garrett
Boost : 28
Videos
Hookzup's talon Tsi 524 awhp Dyno @ Fftec in Hayward ca
28 psi on 3582 with Sunoco gt plus 260 109 unleaded race gas car makes 456 on 91 pump gas and still has not lost a race
including an r1 through the redwoods in norcal
