BADMF's Eclipse GST
- Year
- 1991
- Model/Trim
- Mitsubishi Eclipse GST
- Transmission Type
- Manual
- Mods-Bolt-on
- 6152 60/1 ball bearing turbo pte,750 injecters,255 walbro,aem fuel rail,fuel lab fuel pressure reg.,all the braided lines and AN fittings,b&m fuel pres. guage,inline fuel and oil filters,after market oil cooler,bored out to 63 mm throttle body,bored out evo exhaust header,dump tube,2 1/2 in.magna flow exh.,no cat,2g mas,apexi air filter,2 1/2 in. intercooler piping from the TB to turbo,altima batt. yellow top,two 12 in. slim fans, 44mm tail waste gate,stainless exth. cover,polyu. all around,clear timing belt cover,obx adj. cam gears,koyo rad.,gates racing hoses,t-bolts everywhere,forged blow off,ngk 9's,ngk blue wires,etc...
- Mods-Engine
- Stock bottom,balance shaft elin.,unorthodox crank pully,stock head w/comp cams, BC springs and retainers,3g lifters..
- Mods-EMS & Logging
- dsm link,knock box,turbo timer,all the goodie guages we all have!!
- Mods-Drivetrain
- fully built b&m trans,2600 act,act fly wheel,ext. rod on slave cyl.,syb.shift bushings under shifter,green shift cable bushings,b&m short shifter,new oem shifter cables...
- Mods-Handling
- Megan racing coilvers,front & rear sturt bars, all poly bushings...3000n\t duel piston calipers,hawk pads,racing hart C4 18x8 rims,dunlop tires...
- Parts Wishlist
- front and rear sway kits,carbon hood,hatch,doors,gas door!!
- 1/4 Mile E/T
- 0.000
- 1/4 Mile MPH
- 0.000
- 1/8 Mile E/T
- 0.000
- 1/8 Mile MPH
- 0.000
- 60' Time
- 0.000
- Dyno TQ
- 0.0 lb/ft
