Street beast
- Ownership Status
- Currently Own
- Year
- 1990
- Model/Trim
- Eagle Talon TSi AWD
- Transmission Type
- Manual
- Build Type
- Street
- Drag Race
- Mods-Bolt-on
- T3 super T70 turbo non ebay
Delphi 1600cc injectors
4" k&n intake
Greedy fmic
Greedy 3" intercooler pipe kit
Dsm hot kit manifold
Magnus cast intake manifold
38mm tial wastegate
Magnus billet fuel rail
Coil on plug kit
Hks ssqv bov
Poly motor and transmission mounts
Methanol injection kit
70mm throttle body
Light weight pulley kit
4" turbo back exhaust
- Mods-Engine
- Stage 3 Buschur racing head
Gsc 280/280 cams
Buschur dual valve springs
Buschur retainers
Buschur stainless steel valves
Arp head studs
Arp man studs
Arp rod bolts
Crower "I" beam rods
94 mm eagle crankshaft
86.5 mm wiseco 8.3:1 pistons
- Mods-EMS & Logging
- Apexi safc II
Maf translator
Aem 60 psi boost gauge
Aem Wideband afr gauge
Aem 100 psi oil temp gauge
Aem voltage gauge
Aem egt Pyro meter gauge
- Mods-Drivetrain
- Shepp stage 3 trans
Comp twin disk clutch
Comp Street flywheel
Stock transfer case
3.5" aluminum driveshaft
DSS 1000hp rear axles
DSS 1000hp front axles
- Mods-Handling
- 15×10 rims
26×12×15 Mt slicks
- Parts Wishlist
- Dsm link v3, 100 mm crank for 2.3 stroker build
- Dyno HP
- 784.3 whp
- Dyno TQ
- 766.8 lb/ft
- Dyno Type
- DynoJet
- Dyno Shop Name
- j&k tuning. Family owned shop
- Dyno Session Details
- 45 psi
E85
3 runs. 1- 25psi 2- 35 psi 3- 45psi
No nitrous
