aspekt9
- 344
- 4
- Dec 25, 2005
Boston,
Massachusetts
During idle, although it could be during normal driving conditions as well, there is white smoke coming from my valve cover breather nipple, as well as from my valve cover which can be seen when I remove the oil cap. I recently, as in less than 300 miles ago replaced my turbo because the old one had a seized wastegate flapper. I just replaced the hot side because I figured the cold side was fine. I can still boost fine and there is almost ZERO shaft play side to side and none in and out. I also burn through oil like crazy, almost a quart in 100 miles or so. Coolant seems to stay constant which is contradicting the white smoke I see, although I suppose it could still be indicative of the turbo failing.
I have replaced my PCV valve checked the line off it making sure it's clear, it was. I noticed that my oil return line is leaking where it goes into the oil pan a bit, nothing major though. I also noticed oil on the v-band clamp and it looks like it dripped down from the turbo possibly. My question, would a failing turbo cause these symptoms of white smoke coming through the valve cover? Can the turbo still be blown if there is hardly any shaft play? I've done a compression test before the symptoms got this worse and it was: 190 190 165 175, so the other possibility could be the rings or ring lands on the pistons I suppose, what would be the best way to go about diagnosing the source?
This is a N/T to Turbo conversion by the way, hence why the compression is high, I kept the stock N/T internals.
Also before this all happened, I was doing a 2nd gear pull and I saw a cloud of blue smoke puff out of the exhaust and that was when I did the compression test. Then the smoke got worse which is what I describe above.
