er82
- 247
- 35
- Apr 18, 2014
Sacramento,
California
I keep noticing that after shutting engine off, sometimes it stops in a way that timing belt is loose and feels like I could pull it off the exhaust cam gear. However, when I rotate engine by hand its tight all the way around. Sometimes I can get the grenade pin all the way through, other times the tensioner is a bit compressed, so it seems tight. Is it normal? It has stock cams and cam gears, oem belt, new tensioner and pulleys.
Also I have base timing at 5* on the pulley, but when I point the light on cam gears the marks are off by a tooth. But all timing marks are on point. Is that normal?
