1G Fender Flare Fabrication
stagen
128
19
Nov 28, 2007
Chippewa Falls, Wisconsin
Figured I'd post this up to hopefully keep me motivated to work on this more.
In the process of designing/fabbing some flares for my '91 Talon. With my wheel setup, 17x9 +22 on 255/40s, I had about 1 - 1.5" of poke with camber set for street use. If the mold turns out well enough I might try selling a few sets.
Started by glueing some foam blocks to the taped up fender. Nothing fancy, its used for floral arrangements, sands super easy and doesn't dissolve under fiberglass resin.
1G DSM flare design
by Michael Hagen, on Flickr
1G DSM flare design
1G DSM flare design
Threw a couple layers of 'glass on, shaped the fender arch with some stranded filler, and rough trimmed it.
Still lots of final shaping and smoothing to do, plus still deciding if I want to add bolt hole locations. I am a fan of the bolt on look.
Now I need to start on the rear, and then attempt to copy everything to the other side.
Untitled
Untitled
Untitled
Looks good man! For all thats involved you should just mold the whole fender. Just my thoughts. Heres mine, im running xxr 527 18x9.75 20 offset and 275 tires.
