Please Support Rix Racing
Please Support STM Tuned
2G Fender Flare Install
yes also interested in which kit it was, I am pretty sure its an frs/brz kit, but looks like version 1 fronts and version 2 rears?
Definitely going to need to have more info on the RB adaptation. What size wheel/tire and offset did you fit under there?
I am going to be attempting this within the month hopefully, was trying to sort out more details myself, but if that doesn't happen, I am just going to go for it
Check out my Instagram and youtube for more photos and info @Lifesabishi the info is there. After that if there are any questions I'll happily answer them once I'm done detailing cars.
If by installed you mean scraping on the floor, falling off, missing shit, and unable to turn the wheel because it wasn't fitted properly. Then yes I purchased it "installed".I was lied to about most of the car. The check engine light was even removed without my knowledge.
If by installed you mean scraping on the floor, falling off, missing sh**, and unable to turn the wheel because it wasn't fitted properly. Then yes I purchased it "installed".I was lied to about most of the car. The check engine light was even removed without my knowledge.
Oh the joys of people not caring about doing the job right the first time.. I've looked at a couple GSTs and the sellers were clearly hiding issues. It's most of the problem I'm having finding a decent GSX.
The flares will be painted black to match the talon's two tone color scheme.
Carbonetics with the wider rear flares.
Do you plan on cutting the fenders and then covering with flares to properly fit the 18x9s? Or will rolling be enough? I'm putting in same size for a street build and trying to figure out the best way
You dont need flares for 18x9. I ran that size and 17x9 and they fit fine with 245 or 255 wide tires with aggressive camber and a subtle drop.
I will be cutting my front fenders. Rears will be high enough not to make contact.
