fourgsixthree33
- 1,244
- 45
- Oct 25, 2010
Athens,
Pennsylvania
Just swapped in a 6 bolt into my 95 tsi. I previously did the 1g CAS mod with my 7 bolt. I got the motor in the car today and it will crank but it will not fire. I tested for spark and i am not getting any.
I have also checked my fuses, made sure things that. Eedex to be plugged in were plugged in, etc. the coil pack, cas, power transistor, coolant temp sensor, and MAF are plugged in. I didnt plug everything in because i want to make sure it runs with no leaks before i put everything else on. Alternator and cooling system is not hooked up either.
Upon trying to diagnose this no start issue, i noticed the CEL does not illuminate when the key is turned on. I know it is supposed to come on for a few seconds and then shut back off. I am hoping my ECU is bad.
I also noticed my MPI relay does not make its clicking noise. I was expecting to hear it when i hooked up the terminals to my battery but did not hear it then either.
If my ecu is bad, will that affect the MPI clicking noise? I pulled my ecu apart and i didnt see anything abnormal.
