jimsgsx
- 803
- 95
- Oct 21, 2013
toppenish,
Washington
Mine has a seal starting to leak and need a new one. Thanks guys.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Thanks man.Just make sure to scribe a mark into the bolt and comp wheel to make a straight line. Then when you retorque after your rebuild it should line back up perfect. Be very gentle taking the housings off. And be sure to get some good assembly lube. And if you want solid boost take some time to port the turbine housing!! Something like this
