Please Support Kiggly Racing
Please Support ExtremePSI
1G aem ugeo
blesi660r
37
7
Jun 13, 2013
north branch, Minnesota
I've done a lot of searching the last two days on here, first I know the ugeo does not pair with ecmlink very well and there are better widebands out there for us to use.
so my Q: I currently DO NOT have link, now I would like to hook this wideband up and I'm wondering how to go about doing so without link, do I wire it in like I have link and change the setting on the gauge to replace my front o2?
I guess I'm looking for a little clarification on what to do, I was getting a little overwhelmed with info.
thank you for any help or links to my questions,
If your wide-band supports narrow-band simulation, then it is fine to wire in as the front o2. The front o2 signal wire would be cut at the ecu leaving space to connect the 0-1v converted signal from your wide-band unit. Tape up the unused connector for the front the OE o2 sensor. Other then that, the wide - band should be straight forward to wire. Make sure you use a good ground and many suggest pulling power from the cig lighter.
Awesome thank you for the clear answer :) , my local forum couldn't help one bit LOL
