7cm2 housing set up for EWG....can I set it up for internal?
14b93
Nov 30, 2014
Raleigh, North Carolina
I have a 7cm2 knockoff housing that is set up for EWG. The hole in the housing that actuator linkage has been tack welded with a bolt.
I'd like to use this since it the 7cm2 knockoff housing is brand new and has been professionally ported out already.
I have a 14b turbo housing that can be a donor.
The thing is, I was wondering if it was possible to get the wastegate flapper and linkage out without damaging it and put it into the 7cm2 knockoff housing.
Any ideas?
Thanks
You'd have to get a new flapper assembly to put it in, then weld it together.
Thanks, the removal process in one piece seems possible, however I am having trouble understanding the process of getting it back in, in one piece.
