subiekillrGST
- 78
- Apr 3, 2005
sacramento,
California
Ok this weekend i finally did a boost leak test. I found two leaks one at my bov, i fixed it with some silicone tape. And the second one is through the pcv valve. I replaced the valve with a new one from autozone...bad idea those leak i found out. So tomorrow iam going down to the dealer to get a oem pcv valve. I would get a lot of pressure through my valve cover, and when i would plug the hose i would not get any leaks. So is this most likely my PCV valve? My boost will go to 15psi then drop to 11 psi, I have the forced performance actuator so i cant wait to hold 15 psi to redline! I appreciate the help.
