HiPsiTsiMike
- 45
- 0
- Jan 30, 2003
NJ
can you cut the balance belt off? without having any motor problems?
and will it give a difference in HP gain?
thanks
thanks
Note: This feature currently requires accessing the site using the built-in Safari browser.
No, There are two balance shafts the belt runs the upper BS. If you cut it the lower BS still spins and the engine shakes. You have to pull the lower BS at the same time that you remove the upper BS belt.Originally posted by HiPsiTsiMike
Ah. I'll bet you found that answer by searching.Lordpaxin said:I had the same question and reasearched long ago, and it was agreed that just cutting the belt is bad idea.
HighPsi92GST said:youd be suprised at how many people just cut it...
marcmsj said:what are these people thinking?
