thedsmsource
- 63
- May 2, 2003
Hey guys, Ok, my 92 tsi has had a shaking steering wheel sinc ei got it about a year ago. It has gotten slighty worse, and i am running out of ideas on how to fix the bloody thing. In my efforts to fix it this is what i have done.
Front Suspesion:
Sandblasted and stripped all control arms, had them re coated
New Ball Joints
Energy Suspesion poly bushings
New Tie rods ends (outer)
KYB Agx shocks
Eibach pro springs
New dual pistons calipers
New brake pads
New rotors
Rear:
Sandblasted rear frame, re coated, new camber bolts all around
New ball joints wherever applicable
Energy suspension poly bushings
New rear swaybar
KYB AGK Shocks
Eibach springs
New rotors and break pads
I have had all new tires, w/ 2 allignments. WTF is wrong with it. Possibly the steering rack? I would really like a manual rack. Help me guys
-Shain
Front Suspesion:
New Ball Joints
KYB Agx shocks
Eibach pro springs
New brake pads
New rotors
Rear:
New rear swaybar
KYB AGK Shocks
Eibach springs
-Shain
front engine roll stop. aka the front motor mount!!! try that they are always goin bad on these cars and they will make the wheel shake like that sometimes!!
Vibration in the steering wheel that starts at around 60mph up till 100 or so then smoothes back out. This happens in 4th gear as well and when coasting out of gear. I have replaced almost as many parts as you as well. When you installed the polys on the front control arm, what condition was the rear pin in that the bushing slides over? It should have fit snug. I noticed on mine that the pin had rusted away some causing play in that area. I didn't replace the bushing but suspect it. It could be the inner tie rods, you have replaced almost the entire suspention why not check them. Also what about the steering colum U-joint? I'm as stumped and agravated as you are
I'm wondering if it has something to do with the power steering pump, maybe the pressure sender is screwed up or something, or even air in the lines, improper fluid type ect.. I don't know just brain storming
If you think about it the drive shaft isn't really connected directly to the car itself. The carrier bearings are connected to the body of the car but the drive shaft itself is being held in place by rubber so it would take ALOT of force to transmit into the body. The rear of the shaft is connected to the diff which is suported by the over built sub frame. The rear wheels are not connected to any steering components or anything so the vibration being transmitted in the rear by the drive shaft would not be easy to feel and further more not be the problem in our case. There may still be vibration in the rear but is going unnoticed. How ever the front of the drive shaft is connected to the T-case, which is connected to the tranny. The tranny is connected to the drive axles (cv joints) which are connected to the hubs, the hubs are basicly connected to the entire front suspention and steering sytem. The tranny is connected to the motor which is connected to the front sub frame and body of the car. So you can see how the drive shaft 'could' cause all sorts of vibration problems in the front wile never being felt directly in the drive shaft area at all. If this happens to be the problem I will be amazed though
