razrman8
- 1,435
- 25
- Jul 7, 2010
Troy,
Missouri
I pulled my rear brakes off of my GSX this week. When I pulled the rotor, I found that some of the parking brake assembly had came apart and was rolling around inside of the rotor. I almost have everything needed to put all new brakes on the rear.
I was wondering if anyone knew of a good write-up/tutorial as far as assembling all the parking brake hardware? I bought a complete parking brake hardware set, and would like to know how exactly I should go about assembling. This is the first time that I have ever messed with parking brakes, so I want to make sure that I do it correctly.
I appreciate your time, and any advice is thanked.
