SIM EVO 8 Forward Facing Shootout Build
TofastForU_99
781
10
Mar 1, 2009
Kalamazoo, Michigan
Hello this is Allen @ Strictly Import Motorsports
We have a new shop Evo.
SIM just recently picked up there bone stock evo 8 with 52,000 on it
2005 Evo 8
Maintenance:
GatesTiming belt
OEM Timing tensioner
OEM tensioner pulley
OEM Idler Pulley
BSE KIT
2x OEM front wheel bearings
OEM Water Pump
New Oem head gasket
Mods:
AEM TRU Time Cam gears
ARP cam gear bolts
Kelford 272 cams
ARP HS
Holset HX35 (7 blade 12cm^2) Rebuilt by Justin THANK YOU!
SIM Custom T3 Divided Forward facing Manifold
SIM custom DP
SIM 3" SS exhaust
Walbro 255
FIC 2150cc injectors
SIM Custom FMIC setup
ECMlink (modified 2g ECU and V3 setup)
Exedy HD Twin Disc
TRE Stage 3 Trans (thanks Jon)
SIM Tune
AEM TRU Boost
AEM Oil Pressure
AEM Wideband
Torque Solutions Solid shifter base bushings
Torque Solutions Solid shifter bushings
Torque Solutions Short throw shifter
Torque Solutions Solid drive shaft bushings
Torque Solutions Rear diff bushings
Torque Solutions Solid motor mounts
Tial BOV
Twin Tial 38mm MVS wastegate
Goals:
Mid 10's @ 30 PSI on E85
Mid 500hp
Run in the max effort class at the 2012 DSM/EVO shootout
Sponsors:
SIM (Strictly Import Motorsports)
ZL (Zoologix)
FIC (Fuel Injector Clinc)
Torque Solutions
ECMLink
TRE (Team Rip Engineering)
Just getting started.
Turbo placement.
Kelford 272's AEM Tru Times with all maintenance and BSE done.
Another SIM Wire Tuck
Valve Cover Powder Coated
Starting Mock up on the T3 divided FF Manifold
Finished mock up
More Pics to come so keep posted. these Manifolds will be available to the public.
Update on some new parts and build progress, ENJOY :)
Evo 8/9 Koyo racing Radiator
koyo cap
New Goodridge Clutch line.
Hallman
Install pics
More to come just waiting on parts.
Some more pics guys and gals enjoy and keep posted.
-16 AN setup for the Radiator.
weldable bungs -16
Oil feed and return
THANK YOU JUSTIN (JUSMAX) NEW HX35 7 Blade
Thanks guys.
Yes we are feeding it from the cylinder head. You can get the line from aero quip frangola vibrant carries some an fittings.
Did you mean Jusmx141?
Just figured I'd ask :p
Looks great, hopefully will be seeing you in a month or so for that meet.
Shop looks great too, jealous!
I was under the impression that the head doesnt produce adequate oil pressure for Holsets? Or is there a difference from the DSM to Evo oil pumps?
Im not trying to sound like a dick or bag on the build at all, please understand. Im just trying to help you not have to replace a turbo based on my readings and findings.
Per the Holset faq: "5. The minimum oil pressure when the engine is on load must be 210 kPa (30 lbf/in2). Maximum permissible operating pressure is 500 kPa (72 lbf/in2) although 600 kPa (88 lbf/in2) is permitted during cold start up. Under idling conditions pressure should not fall below 70 kPa (10 lbf/in2)."
http://www.dsmtuners.com/forums/turbo-system-tech/362444-holset-turbos-faq.html#post152124696
And based on this guys thread with a gauge at the head location, 7-10psi at idle and 45 under load you COULD run a feed from there but risk a chance of starvation. http://www.dsmtuners.com/forums/tuning-engine-management/415159-aem-oil-pressure-gauge-sensor-head-location.html
I also found this on FPs site, about 1/4 way down.. Forced Performance Turbochargers
Like I said based on this info it could be fed from there but seems a bit low for a Holset application. Aslo maybe the Evo has a slightly different oil pump?? That Im not sure about, if so this info is irrelevant.. :idontknow:
No no harm taken I love feedback on all of our threads.
I know there is a huge debate about oiling and such and im not saying we are 100% right either. i will be running it from the head the reason for this is just based off prior experiences. We have ran a lot of holset setups on DSM's and Evo's and have ran them at both locations with never 1 oiling issue.
Here are few more pics of the turbo completed.
ENJOY :)
Mmmmm I do love that orange!! I will also definitely keep an eye on this thread on how your turbo is holding up. Im starting fresh with my build this season as well, coming from a head fed 20g to a t3 t/s Holset. If I dont have to buy yet another oil feed line thatd be awesome!!
Right on, Get a build thread going so I can check it out. Thanks for the feedback.
