How can i tell what injectors i have???
Sbeing1
434
2
Mar 22, 2005
Palm Beach, Florida
I bought the car thinking that the injectors were stock, but i checked my friends 95 tsi and his look totally diff than mine so im assuming there upgrades. But how can i tell what size they are, i see the stock plugs say 430 or somthing on top but these dont, its just a white and black plug cap and the injectors are black and silver (if that means anything). If anyone could help thatd be great, thanks.
Is the physical injector diffrent or just the plug. some 94.5 2g's are also commoly labled at 95's but the have the injectors clips from a 1g harness, for example my 94.5 gsx as 1g style plugs my 95 has 2g style clip's
If nobody can tell you what they are then take them out and look up the number on the side of them. Also if they are a significant upgrade you will be running very rich. If your not running rich then I don't think you have bigger or much bigger injectors.
yea im running super rich, i have a 255 too. Sorry about pics they were takin last night at 12.
Do you have any type of fuel management? You need to pull the injectors to find out what size they are because it is almost impossible to tell you what size they are from the pictures since so many injectors look the same. It is not hard at all to pull injectors, and once you do there is a number engraved on the side, I can't remember exactly how it is, but if you put the number up I'm sure someone could tell you what size they are.
For whatever reason the links don't work for me.
The stock 2G 450cc injectors look like this:
The common cheap Delphi injectors upgrades look like:
Which do you have?
Steve
Even with the safc2 and the dsm link (you're using both?), you will need something to manage that fuel pressure. Get an Aeromotive. Worked wonders for me and I am running a 255 with evo 16g. That will fix the richness even if the injectors turn out to be stockers.
MB
i found out today when tunning with dsmlink that i have 550cc's. Thanks for your help guys. nah im not using safc just dsmlink
