Activity Feed
Live updates
  • miliman13 replied to the thread 2G Is this salvageable?.
    · 14 636
    Others have already confirmed it but this is 100% repairable this looks nearly exact to my rust that I just recently completed restoring (on my build journal 📓)One side would crunch when lifted by car lift, from the absence of support from all...
  • GhostTypeP0300 replied to the thread 2G My scan tool and my DVOM disagree..
    · 12 755
    Today the battery and brake like came on at the same time, flashed went away ?And recently my turn signals stopped working but are currently working
  • How can I do this
  • pauleyman replied to the thread 2G First Gear Pops Out.
    · 67 3,237
    I get it but how dedicated are you. If you love the car keep going. Worst trans experience I ever had was 8 trans drops on one weekend. Ive long since been able to buy something else but I just dont know any other car that offers this much and I...
  • tschuhly replied to the thread 2G Is this salvageable?.
    · 14 636
    At the very least someone just posted a really nice shell in the classifieds. You could just use that and swap everything over into that.
  • Wun-jee Claud replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,790 170,186
    Cleaning out the bay to find the spare head... Wasn't planning on it.. but now I need to find that chevette I wanted to throw this in.. can you guess what it is...You must be registered to see element.You must be registered to see element...
  • Wun-jee Claud replied to the thread What did you do to your DSM today?.
    · 12,120 839,989
    Ouch... Least you caught it..
  • jdxnc replied to the thread What did you do to your DSM today?.
    · 12,120 839,989
    Pulled the block and head, definite signs of the gasket being compromised.You must be registered to see element.You must be registered to see element.
  • miliman13 replied to the thread 2G First Gear Pops Out.
    · 67 3,237
    No that bend you see is a swivel end I modified to remove the bending from the cable so when you go left and right it doesn’t cause resistance. You must be registered to see element. Also when I installed the K cables and before I managed to...
  • jersygsx posted the classified ad For sale 1g 1GA Flip Up Weather Seal Set in DSM Parts Classifieds.
    1GA Flip Up Weather Seal Set $25 + shipping and paypal fees* rubber seals are in great shapeYou must be registered to see element.You must be registered to see element.You must be registered to see element.
  • GIB replied to the thread 2G First Gear Pops Out.
    · 67 3,237
    I got the cables installed and tried to drive. It still popped out of first. I tried everything outside of the transmission. I have another transmission that I may install. I may just sell the car at this point. I think I'm done with it for sure...
  • El_marto posted a reply to a question on the classified ad Wanted Wtb turbo manifold.
    Thank you, I ended up ordering a ccdesignfab manifold. It should be ready in a few weeks
  • jmt2028 posted a question on the classified ad Wanted Wtb turbo manifold.
    Check out Artec manifold for 4g63. They make a cast stainless manifold that is a nice set up for around $1200 and is used with a 44mm tial wastegate. I purchased mine from RealStreetPerformance but you can also order them directly through Artec...
  • 1990TSIAWDTALON replied to the thread Help i'm overheating!!! Here's how to fix it....
    · 2 45,394
    Wrapping your turbo with a blanket "can" help, especially if you run an aluminum radiator, as it can pick up radiant heat. Also, you can add a LOWER Air Dam under the radiator, to direct air up and into the radiator instead of it going under the...
  • James92 replied to the thread 1992 Eagle Talon TSi.
    · 6 978
    Finally got the FTP braided lines installed and completely bled and WHAT A DIFFERENCE! haven’t road tested as it got hot out and I still need to degrease and wash the car before putting the wheels on but I am happy.Still need to adjust the...
  • Turbski91 replied to the thread Old Man Tan.
    · 48 5,203
    Today was a very productive day. Rebuilt the driveshaft with OEM carrier bearings, and GMB U-joints. Unfortunately I forgot the lobro boot at home. So I will have to split that again at some point. Was also able to tackle the rear bushings, new...
  • 1990TSIAWDTALON replied to the thread ECMlink Speed Density Switch No Start.
    · 45 1,388
    I have three 1g's. All run Ecmlink and all are set at .63v at idle. Sometimes that will go up .01 when the motor starts. I would suggest this for the TPS as it makes manual adjustments much easier. DSM TPS Bolt Mod for easy adjustments |...
  • GoldNugget90 replied to the thread ECMlink Speed Density Switch No Start.
    · 45 1,388
    You're right, I have been connected to the battery without a start, I'll get it charged before proceeding. I'll check voltage also, however, I've read a little on this and .48-.52v may be OK for a 1g? The global fuel is as ECMLink calculated, and...
    · 67 3,237
    You must be registered to see element. I found a BROKEN BOLT on the rear mount. The bolt is broken up high enough where the mount doesn't slide. The mount rubber isn't cracked.
    · 67 3,237
    The cable on the right looks really bent. How did that work?
