Activity Feed
Live updates
  • Turbski91 replied to the thread Old Man Tan.
    · 48 5,105
    Today was a very productive day. Rebuilt the driveshaft with OEM carrier bearings, and GMB U-joints. Unfortunately I forgot the lobro boot at home. So I will have to split that again at some point. Was also able to tackle the rear bushings, new...
  • 1990TSIAWDTALON replied to the thread ECMlink Speed Density Switch No Start.
    · 26 731
    I have three 1g's. All run Ecmlink and all are set at .63v at idle. Sometimes that will go up .01 when the motor starts. I would suggest this for the TPS as it makes manual adjustments much easier. DSM TPS Bolt Mod for easy adjustments |...
  • GoldNugget90 replied to the thread ECMlink Speed Density Switch No Start.
    · 26 731
    You're right, I have been connected to the battery without a start, I'll get it charged before proceeding. I'll check voltage also, however, I've read a little on this and .48-.52v may be OK for a 1g? The global fuel is as ECMLink calculated, and...
  • GIB replied to the thread 2G First Gear Pops Out.
    · 57 2,873
    You must be registered to see element. I found a BROKEN BOLT on the rear mount. The bolt is broken up high enough where the mount doesn't slide. The mount rubber isn't cracked.
    · 57 2,873
    The cable on the right looks really bent. How did that work?
  • pabafree95 replied to the thread 2G Is this salvageable?.
    · 14 523
    Ha ha got it . I guess I would have at least 60 seconds and pull over thanks man. I hope you guys have a great weekend.
  • diambo4life replied to the thread ECMlink Lowdoller Map sensors.
    · 18 594
    What's your elevation? Go through your wiring or pin assignments again. Double check your calibration curve. It's always something small that's overlooked.
  • Vladimir replied to the thread 2G Is this salvageable?.
    · 14 523
    When your doors suddenly go out of alignment, your steering wheel develops a little death wobble, and your suspension starts feeling like your grandma's air mattress, that would be a good time to call give her a last hug and pull her heart out...
    · 14 523
    Got it that’s very useful information. Thank you so much really appreciate it.I’ve never had a car this long. Never mind the rust . Is this the kind of thing where you take one turn hard and the car just falls apart? Understandably I’ve been...
    · 26 731
    I looked the settings over and didn't notice too much, but what I did notice, I took a picture of. It looks like you need to charge the battery, I am surprised it ran at 8.? Volts. You've probably been using the battery alot. Charge it up good...
    · 14 523
    If you are doing all the welding and fabrication yourself it would make sense to fix her and get most of the structural integrity back. That is if you got plenty of free time to do it. Here in the Midwest most of all 20 year old car starting to...
    · 14 523
    Hey Jesse - thank you so much for taking a look for me! I know you’re very experienced. I’ve seen several of your posts. So that’s giving me a glimmer of a hope. I was able to track down a Mitsubishi car enthusiast not too far from where I live...
  • jesse12345 replied to the thread 2G Is this salvageable?.
    · 14 523
    It looks like alot of the structural part of the car isn't fully gone. Most of what I see looks like the rockers which are the first to rust along with strut towers. I know when they get to be this rusty I try not to lift by the pinch rails. I...
    · 14 523
    cool look forward to getting his take. here is the outside (: didnt want to start with that. doesnt matter at this point, just wanted to show her off.You must be registered to see element.
    · 26 731
    No not yet. I wasn't sure the best place to start troubleshooting, but I'll give this a shot and see what happens. Thanks for the starting point/suggestion.Added to original post
  • pabafree95 posted the thread 2G Is this salvageable? in Custom Fabrication.
    Hello - i am the original owner 1995 eclispe GST 5 spd, 110,000. recently shop told me to get the rust addressed. ive reached out to a few people and will be getting it assessed. I had the front crossmember replaced in 2016 along with repairing...
  • diambo4life replied to the thread Street Build Project 9s: Street Driven 98 Eclipse Auto.
    · 138 21,231
    Okay. Looks like my tweaks worked, a little less boost than previous pull, worse DA (3500') than post You must be registered to see element. and finally hit that 100mph in the 1/8th. I don't have the weird 1-2 shift anymore. Spark plugs look...
  • Hi guys!Can someone tell me if it's possible to replace only the two bushings that hold the steering rack in place? I'm talking about MB315228 + MB501119. One of which I was able to find OEM on Ebay, the other I've had 3D printed out of TPU...
  • SixBolt_16G replied to the thread ECMlink Speed Density Switch No Start.
    · 26 731
    You should post the actual .elg log file so that we can see your other settings. PDFs dont tell the full story.
  • Josedsm posted the classified ad Wanted 1g throttle 91 to 94 60mm in DSM Parts Classifieds.
    Im looking for a working throttle body or in decent condition. Its for the 1g intake, i did a 6 bolt swap and have the 2g throttle for now on it and want the 91 or 94 throttle body for the 1g intake send me a pictures and price
