Activity Feed
Live updates
  • Vladimir replied to the thread Resolved 2G A/C system not working.
    · 131 3,777
    There is not much going wrong. The system is clogged with something for sure. Pressures equalizing in the morning does not mean it will work now. It will be the same issue again if you force the compressor ON. Expansion valve and dryer at the...
  • GhostTypeP0300 replied to the thread 2G My scan tool and my DVOM disagree..
    · 12 680
    Thanks,the engine was offI also noticed a red wire with tape going to the back of the dlc when I was under there
  • cswindel replied to the thread Resolved 2G A/C system not working.
    · 131 3,777
    I looked up some YouTube videos and all of them had about the same steps that I followed: - hook up manifold - pull vacuum on just middle/yellow line - open HI and LO side on manifold and let vacuum pull for about 20 min - Result was about -28 in...
  • 4gfun replied to the thread What happened to dsmecu.com?.
    · 5 432
    Thanks for the help. Was really an icebreaker for me to see what was out there. Back to the rot!
  • Smokingasphalt replied to the thread The Side-salad.
    · 11 866
    Appreciate it! Yeah the fbody has a 427/T56 in it. It's been parked since I split the input shaft on the trans a couple of years ago (T56 Magnum is waiting to go in with some power adders).I agree, shouldn't be too hard of a repair on the...
  • dwdsm posted the thread Maher relocation kit questions in Handling Tech.
    Anyone else have the Maher power steering setup? You must be registered to see element. Since I put it on it wiped out a pump and a brand new rack shortly after. Them pump just blew the o-ring separating high and low so I don't think it was the...
  • dwb replied to the thread Resolved 2G A/C system not working.
    · 131 3,777
    Did you pull a vacuum on the system with a vacuum pump after opening it up? Did you flush the system or add any oil to it?
  • steve replied to the thread What happened to dsmecu.com?.
    · 5 432
    From what I remember, Jonathan started and ran the site for awhile and then let Kim take over the hosting (after a crash or something) Kim was in the Northwestern Europe countries (Netherlands, Denmark, Sweden or Norway) and disabled. Something...
  • dwdsm replied to the thread *** 2G DSM Quaife quick rack Group buy 2026 ***.
    · 37 6,994
    If anyone wants to back out let me know. My power steering is giving me a heck of a time since putting in the Maher kit... If the design is to blame I can't be going through racks and pumps monthly...
  • steve replied to the thread 2G My scan tool and my DVOM disagree..
    · 12 680
    Much better this time, thanks.I assume that voltage measurement at the OBD2 port wasn't with the engine running. If it was there's a huge drop between the alternator output and the OBD2 plug which could explain the Scanner complaining or you...
  • schmitty_z replied to the thread The Side-salad.
    · 11 866
    That thing is looking so good! The f-body is a sweet unit as well :thumb: bummer about the fenders.. at least the damage looks minimal and not in a spot where it will draw much attention. Shouldn’t be too bad of a repair!
    · 5 432
    I don't know who that is.Sorry to be cryptic but I remember the forum being dark and dreary but lots of ECU tuning. Looks like "Jordan" ran that. Not sure who Jordan is either.You must be registered to see element.
    · 5 432
    Was that the site that Kim was running?
    · 11 866
    I still have plenty of maintenance and performance parts to install when I get some time. I fixed some rust areas behind the rear bumper and plan to tackle some rust areas in the front in the near future. I installed a Turbosmart Eboost...
    · 131 3,777
    Should I try and kick it on or do you think it won't matter if there is a blockage even if I were to force the clutch to engage again
    · 11 866
    So far the car has been somewhat reliable. I drive it to lunch a few times a week.One of the coil packs went out, didn't take too long to figure that one out.Had a major fuel leak between the engine/firewall. I had overlooked a dry...
  • pauleyman replied to the thread Resolved 2G A/C system not working.
    · 131 3,777
    That looks about right. Both gauges are reading the same. Compressor kicks on low side should be maybe 30 to 40psi and high side 150 to 250 depending on outside temp.
  • ItsTwan309 replied to the thread 93 TSI (Samurai Black).
    · 34 3,169
    Got my fuel pressure gauge mounted. Need a new oil pressure gauge to fill the hole of the dead gauge on the right.You must be registered to see element.
    · 34 3,169
    Ended up installing a buss bar and two fuse panels in the glove box. (will clean up wire paths when I install the next gauge) Left panel is constant 12v, Right is ignition power. Installed a relay behind the glove box to power the ignition power...
    · 11 866
    I still have yet to install the carbonfiber fenders because both arrived damaged. Working with the company to file a shipping claim (happened three times). After the last time at least the passenger side was undamaged. So now I think I'm going...
