Activity Feed
Live updates
  • Absolutely! Meeting expectations is everything, for both our distributors and their customers. This sort of feedback helps us find areas where we can improve, so thanks again!I will be sure to share this with the team here as we continue...
  • steve replied to the thread 420A Help with good brake pads/rotors replacements.
    · 27 1,009
    Stock 2G AWD brakes. That's exactly what I was suggesting. For me it was a night and day improvement over what was on my car originally and I suspect the same would be true for any of the FWD cars RS to GST.
  • pauleyman replied to the thread 420A Help with good brake pads/rotors replacements.
    · 27 1,009
    I mostly quit buying over the counter awhile ago and buy online. On the older cars its orders of magnitude cheaper. For instance I stock up on windshield wipers at 3$ instead of 15 to 20. Brake pads online are very inexpensive.
  • pma1123 replied to the thread So what are you working on that’s NOT your DSM?.
    · 1,785 167,141
    This week is 2018 Honda V6 with 107K mi stuff in the evenings. (MDX) Aisin timing belt set, valve adjust, intake valve cleaning, coolant flush, $park plugs, driveline fluids, bleed brakes, etc.Thus far I can say the PCV was super dirty and...
  • steve replied to the thread ECMlink Help me learn to tune injectors.
    · 26 1,049
    Before V3 you only had the global to work with and it was applied to whatever the internal map was interpolated to. Those of us who worked directly with the factory binary would go and modify what ECMLink calls InjBatteryAdj.It's my...
  • DSSA replied to the thread Just call it what it is---King Bearings are no longer an option.....
    · 32 5,153
    Much appreciation you coming on here and giving an update.It is frustrating when critical parts go on back order status, especially when the OEM units have been disco'd for some time.My biggest frustration with the years-long back order, was...
  • Raider_831 replied to the thread 420A Help with good brake pads/rotors replacements.
    · 27 1,009
    I really like your idea, I kind of tried it once we re did the job and lubricated the necessary parts even shaved the shims to fit better. My mechanic did look for wheel hub bearing but he said it wasn’t needed on my left side. My right side...
    · 27 1,009
    Fair point. I knew you were talking about a brand.I run stock size brembo rotor blanks. Theyre coated and wear well. I picked a brand name non organic pad. Works fine for what I do. If I tracked the car i would pick something different. I also...
  • We realize that this is a bit of an older thread, but we felt it is still relevant enough to respond. We completely understand the frustration when parts are not available, especially if you can't get them when you really need them. We are...
  • Tony1094 replied to the thread ECMlink Help me learn to tune injectors.
    · 26 1,049
    When you make the DA change to 0 out the global deadtime, are you offsetting for the voltage differences as well? Just curious how you set it up, I'm still super new to ECMLink and trying to learn it and the theory behind it. I was only trying to...
    · 26 1,049
    Global Deadtime and InjBatteryAdj are the same thing the two are summed together to arrive at the injector deadtime the ECU uses. I prefer once things are dialed in to update the DA table and leave the global at 0 but that's to eliminate...
    · 27 1,009
    Perhaps we are being confusing, I think the Brembo parts being considered are pads or rotors not some BBK.
    · 27 1,009
    I'll chime in. As with any part/mod what do you need it to do? Are you repeating 120mph stops on track? No? Then you don't need large brakes. Can you do them anyway? Sure. Is your car primarily a driver and you dont exceed 75mph? Likely any stock...
  • pma1123 replied to the thread Old School DSM & 4G63 goodness-Ads, Commercials, Tuning etc..
    · 592 82,999
    DSM Laundry (actual factory uniform shirt)You must be registered to see element.
  • Brandon Mau replied to the thread 1G F4A33 Transmission Issues.
    · 9 460
    I would pull the front differential drain plug as well as you stated. Start out with 1 gallon, start the car, put it through every gear on jack-stands to get the fluid pumping through the entire thing. Then put it in neutral running and add fluid...
  • Moneypit91 replied to the thread Black Cherry.
    · 6 1,193
    First time off jack stands in 9 years! You must be registered to see element. You must be registered to see element. I'm moving the car to my shop tomorrow to get it on the lift to complete the next phase of the build. Going to clean and restore...
    · 26 1,049
    From what I can see, the reason your global deadtimes are so high is it looks like you didn't put the injector data in to the Direct Access InjBatteryAdj table. You'll have to interpolate some values but for example, your log shows @ 12v your...
  • MikeyTsi posted a reply to a question on the classified ad Wanted 2gb OEM front bumpercover.
    Not sure of your location, but Pick-n-Pull nationally shows 4 2GB's: You must be registered to see element.You'll probably want to find something local enough to pick up because bumpers are a pain/expensive to ship.
  • Vladimir replied to the thread Resolved 2G A/C system not working.
    · 131 3,839
    If you can spin the compressor clutch by hand and it's not binding, compressor is not seized. As long as the compressor had no open ports in which the dirt and water was constantly falling, it should be alright. I do believe you can just buy a...
  • cswindel replied to the thread Resolved 2G A/C system not working.
    · 131 3,839
    Yeah you know banging on stuff has worked for me many times. Reminds me of my motorcycle starter haha. Yeah I'll give that a try and see. It seems everything that needs power is getting power so im just lost on if it's electrical or if it is just...
