Activity Feed
Live updates
  • Dihtung Glava replied to the thread Street Build Dihtung Glava's Eclipse.
    · 103 18,066
    I'm glad I could be of help😇🤝
  • Brad Bell replied to the thread 420A 2nd gear grind after rebuild.
    · 9 671
    I've done some more research and came across this post describing a similar issue of the shafts moving axially within the case. Although this one has more to do with 5th gear popping out. I recall when assembling my case during the rebuild, there...
  • rigsan22 replied to the thread Street Build Dihtung Glava's Eclipse.
    · 103 18,066
    Dude this literally has had me stuck for over a week, ive been losing my mind thinking I had plugged the fans up incorrectly to the vehicle harness. I had also tested my fans with a power probe and, since misbimoto doesn't have any sort of wiring...
  • Aug 1, 2026 at 10:00 PM → 11:00 PM
    Hey everyone! LancerNation Mitsubishi Owners Day is back again this year. And this year we are expanding to 2 events! We are teamed up with Rix Magazine happy to announce our second event for the East Coast. Come down to Liccardi Mitsubishi and...
  • IHeartMyHonda replied to the thread New Product!! 2G DSM AWD-swap bushing kit.
    · 17 8,233
    Yes, that sleeve must be removed. Yours has a bit more rust than mine did, but it shouldn't be difficult.I cut a couple of slots straight down into the sleeve with a sawzall blade then peel the sleeve out with a hammer and chisel. It took me...
  • AirForcedDSM replied to the thread New Product!! 2G DSM AWD-swap bushing kit.
    · 17 8,233
    Im working on removing the stock subframe bushings to install the swap bushings. Do I need to remove this lip looking piece from the borehole in the four corners?You must be registered to see element.
  • We're on Boost replied to the thread ECMlink Baro decreases during WOT.
    · 4 627
    Here's a log from a 1995 GSX with a 2g MAF and some healthy mods, and he was capturing values for Baro so you can display Baro in the log. His Baro numbers are doing the same thing yours are. His go down a little more than yours during hard...
  • miliman13 replied to the thread Venezuelan E33A.
    · 39 3,147
    If for what ever reason you can’t get link or use ECMLink, since your an engineering student you may feel comfortable with Speed-duino a stand alone ECU you make based on the Arduino platform. - just a thought 💭.Look into it if it interest you.
  • victorgalant replied to the thread Block inspection Good or Junk.
    · 4 487
    Personally, I'd go with sandpaper first. On the mating surfaces just take a 4x8" glass and use 400 grit for the first pass, if it cleans up, you could use 600 and then 1200 to give it a finish. Don't go too crazy on it, 10 passes on a figure 8...
  • Hobishi added a vehicle profile titled 91 integra rs to the 4G63t Swapped section.
  • victorgalant replied to the thread Venezuelan E33A.
    · 39 3,147
    Also wanted to share some of the thoughts i had the past week.Since i got motivated to finish the car, the big question came: what are you going to do with it? So I (kinda) came up with a plan for the carAs i said before i really don't trust...
    · 39 3,147
    Thanks man! I try to do things by the book, but sometimes you just gotta wing it and see what happens.Really happy to see that people care, rn my Vitara and uni got my tied up, but that thing is gonna run this year. Shout out to my broken...
    · 39 3,147
    Thanks for update - share pics when you can !! Real impressive your resourcefulness, big fan.Hope to see more.
  • voodoogsx replied to the thread 2G 95 GSX barn find, first steps recommendations.
    · 58 6,141
    I had a bad IAC a long time ago and the symptoms were a little different from my recollection...I had a high idle that never really went back down, I think around 1100. Like I said, I only mentioned the fuel pump thing as it was fresh in my mind...
  • 92AWDHX40 replied to the thread Project Jade Continutes.
    · 416 64,545
    She's coming together waiting on my hood, and welder to work my v band for my wastegate and downpipe. Then irs really looking like my dream dsm. Lots to do later. But now road worthy soon
  • Phillyboytye replied to the thread 1997 Mitsubishi Eclipse GSX.
    · 2 350
    I ordered black molded cut pile online. The first installation attempt didn’t go so smooth because I overcut the carpet where it clips underneath both rear panels and door seal trim. I had to reorder another carpet set and this time stretched the...
  • pauleyman replied to the thread Block inspection Good or Junk.
    · 4 487
    I didn't even flinch. machine shop will take care of that. Cant see it in the pics but only gotcha would be severe pitting.
  • Furiyous replied to the thread Spyder Stuttering/Skip/Misfire.
    · 12 643
    Thanks for that thread. I did check and read through that, mine doesn't have an issue starting after warming up. It starts up every time just fine with no issue. Its just skipping/hesitating. Like as if a spark plug was bad or not getting enough...
  • GIB replied to the thread 1997 Mitsubishi Eclipse GSX.
    · 2 350
    How'd you do the carpet?
  • 92AWDHX40 replied to the thread What did you do to your DSM today?.
    · 12,094 833,521
    Spent all day in the garage today moved harness near shifter cables, 95 percent of engin bay stuff done now. Wiring interior tommorow, hood is being made still .
