Where can i find head/tail lights with orange blinkers?
GeeZuzz
69
Dec 23, 2005
Norway, Europe
In my country the cars must have orange blinkers both in head and tail. Also, the parking light(?) must be white.
My car have red tail blinkers, and in front the parking light is orange.
Does anyone know where i can find tail lights with orange blinkers? And head lights with blank parking lights?
I was hoping to find something cheap on ebay, but everybody have the same USA versions i already have :(
Your headlights should have orange blinkers and blank/steady parking lights in them. Are you sure you are using the right bulb?
www.machv.com has european tail lights for $539. http://www.machv.com/eurtail.html. They pop up on ebay once in a while, but when they do a lot of people want them, so expect to pay a lot for it.
539$ was very expensive.. OMG
Hidden among all the tail lights wit all red glass, i found one that is exactly like mine, except it has one blank glass at the side. I think that will do :) If anyone find any other please let me know..
Yes, the headlights have orange blinkers, but the blinkers are also parking lights (orange). I'm not sure my lights are original - does the original ones have blank parking light?
Check your local regulations. If they require you to have a reflective yellow surface on it, the lights on the link above won't work. If all you need is a yellow light at night, that is good.
So if you have orange blinkers and parking lights, what are you looking for? Clear lens?
These are factory lights
The ones below are aftermarket ones from ebay
The parking lights can't be yellow in my country - they need to be white. Thats the problem... So the blinkers must be yellow, and the parking light white. Thats a problem when the yellow light is both blinker and parking light. :(
I have those lights from ebay on your bottom image.
Interesting. You might have to make something yourself. Install a white bulb in the parking light and drill a hole in the clear lens and put an extra bulb (yellow) in the drilled hole for the blinkers.
