What fuel pump do i have?
bsbllfit7
1,104
3
Feb 17, 2009
Salem, Oregon
I am just trying to figure out a way that i can tell if my fuel pump that i have in my car is stock or if it is a wally 190 or something. I have recently installed a 14b and can hit 17-18 psi without hitting fuel cut so i am wondering if the owner before me had put in a 190lph fuel pump. Lemme know cause if i have a 190 in there i am gonna keep the boost up!
I wouldn't think we could give you a 100% definite answer on that. You might need to pull the pump and check markings on it.
You shouldn't be upping the boost like that with no way to monitor your engine's vitals (logger)
My friends GSX creeps to 18psi on her 14b on stock injectors and fuel pump. The only way to tell what pump you have, is to check it out. You can't just guess.
the car is set at 1 bar or 14.7 psi of boost. I originally had had the boost set higher on the mbc from the previous turbo and it jumped to about 18 psi with no fuel cut thats what i meant ha sorry bout the confusion. And yes im just trying to find what the markings would be if it was a stock fuel pump or a 190 lph. I plan on taking a look either today or tomorrow and just wanna know what to look for!
