Welded Center Differential AWD Trans, binding?
I accidently said it was you. I meant someone else. Sorry for the confusion. I was referring to the dsmlink thread and got my people messed up.
Well, I think I may have figured out my problem. I was underneath of the car unspecting a whole bunch of the stuff. I noticed that one of the carrier bearing bolts on the driver axle is broke off:ohdamn: I am pretty sure that this is where all my shaking of the car is originating.
Sorry I haven't posted back at this for a bit. But I am still having my problems. I haven't fixed the carrier bearing, but as I continue driving it, I'm not convinced that It's the carrier bearing up front.
This horrid vibration is coming from the rear of my car, and its gets overly obnoxious. I've checked gear oil in rear end and its full. It gets the whole rear of the car going. I don't know what to think it is.
You haven't verified if you have a matching trans/x-case, you haven't fixed the carrier bearing.
What else do u want people to tell you? ROFL
Ok well then since the only things you changed before this problem started happening is the tran/x-case i would start with that.
Swap a working x-case with a another one since that is easier to do, if the issue is still there then pull the trans and either have someone who knows what there looking see it, and/or throw another trans in there to verify that one is the issue.
Before all that hard work i'd raise all 4 wheels off the ground and put it in gear and try to track down where the noise is coming from.
