weird boost level changes
chavez408
1,115
Dec 13, 2003
Bay Area, California
Hey guys before anything, I will be doing a boost leak test but I would like to know any other posibility on what is going on.
To make it short, this morning I decide to do some quick pulls on my car. And I got some weird boost level settings.
2nd gear at wot 10 psi..
3rd gear at wot 15 psi and pulling..
4th gear at wot 15 and pulling!
5th gear, was at 10 psi.
Mods are in my profile, not including the 225 wally and injectors.
And I just re check again, and did the same pulls oveer again and all gears hit 11 psi steady. What is going?
I am guessing the boost levels per gear were the highest you could reach. If it runs bad you got a boost leak if it runs good maybe your gauge line is loose or a broken gauge.
Id look to your MBC, when they leak they can add more boost in a load. Mine was disconnected and I would go infinate. Not really any power, but just infinate.
