o2 Volts drop at WOT!
Benji
117
Mar 14, 2003
I've had this problem for months now. I really need to get this fixed since it's starting to get nice out.
91 GSX. 190LPH, Ported 14B and o2 housing, MAF-T 1.3, Blow through, 3" GM MAF, Stock SMIC, Stock Injectors.
At WOT, the o2 Voltage drops between 0.02 to 0.08V. Weird thing is that there is not knock, timing is between 18-22 degrees. The car bucks at this point.
Starting problems are also present. It's worse after you drive it for a while, shut it off and restart it.
Changed the ECU, plugs, wires, Coipack, MAF-T.
Any ideas?
O2 sensor, I had the same problem. It's not a fuel problem otherwise you would be knocking.
I was hitting fuel cut and not knocking. This sounds exactly like the problem i just had with my car. It was fuel cut because my boost was creeping to 17-18psi. How much boost are you running?
Fuel cut has nothing to do with knock. Hitting fuel cut without knocking is nothing abnormal.
My money is on a dead O2 sensor, or wiring.
o2 Sensor has been replaced with a Brand new one. It cycles (near) normal at cruise, only drops at WOT!
my car did the same thing even with a new 02 sensor my boost creeps up to 17-18psi and i get a pop. On my logger my timing was between 18-20* 0 knock and my o2's dropped to .02 i unhacked my maf and put the silencer back in my intake and put in the silencer that came with my n1 exhaust and now i have no boost creep and at 12psi i have no pop at all i am willing to bet its fuel cut. Do you have a boost gauge so you can tell us how much boost your running?
Be sure your ground is hooked up properly on your downpipe. My o2s would hit around .88 when I first got on it, but when I hit boost, I would fall right down to .02 or so. I hooked my ground up properly and it's running fine now. It's worth checking out, might save you from having to buy a new o2 sensor.
same thing happened to me. It was a bad O2 sensor. would cycle normally, then at wot, as I was rich, and the o2 volts approached .98v, any higher and they would suddenly drop to .02v, instead of going to 1.0v. I got a new O2 sensor, and fixed it.
I just can't see it being the O2 sensor still as I have replaced it. Anyone think of anything else this could be causing?
This is the third time I ask you HOW MUCH BOOST ARE YOU RUNNING?? I bet with your exhaust your boost is creeping at higher rpms and cause you to hit fuel cut. At what rpm's does your car buck?
I used to run about 15 psi but now the car bucks at 8 psi. It can be at any rpm point when this occurs as long as I am starting to build boost.
:cry:
Do you have a boost gauge or are you going by the one on the dash? How do you run such low boost with 2.5" turbo-back exhaust?? My talon had 2.5" turbo back with a high flow cat and it used to creep to 16-17psi even with a hose going straight from the turbo outlet to the wastegate actuator.
Again, have you checked this out?
I only creep a couple psi at really low temperatures. On a fairly nice day, I have very little to no boost creep!
I have not yet, but will here shortly. Even though I can't see this being my probelm, it is definately worth checking into!
On my 90 Talon TSI AWD, I had replaced the o2 sensor with a brand new one...problem was I got one from Schucks. If you replaced your o2 with an aftermarket, get an OEM Sensor. My "new" Schucks sensor would not read fast enough at WOT and just fall out, especially up hills. I swapped out with an OEM O2 sensor and everything is fine now.
Here are some logs and files for everyone to look at.
Here is the first Log. Below you can also find a link to a picture as well as a txt file for easy viewing.
IDLE ONLY LOG
IDLE LOG
Time, Hz , RPM, IPW ,Knock, o2, TPS ,Timing
0.00, 50.38, 875, 2.56, 0, 0.78, 13.73, 13
0.13, 50.38, 875, 2.56, 0, 0.78, 13.73, 12
0.25, 50.38, 875, 2.56, 0, 0.78, 13.73, 12
0.38, 50.38, 875, 2.56, 0, 0.78, 13.73, 12
0.50, 50.38, 875, 2.56, 0, 0.76, 13.73, 12
0.63, 50.38, 875, 2.56, 0, 0.76, 13.73, 12
0.75, 50.38, 875, 2.56, 0, 0.74, 13.73, 12
0.88, 50.38, 875, 2.56, 0, 0.72, 13.73, 11
1.00, 50.38, 843, 2.56, 0, 0.68, 13.73, 12
1.13, 50.38, 843, 2.56, 0, 0.64, 13.73, 12
1.25, 50.38, 843, 2.56, 0, 0.33, 13.73, 12
1.38, 50.38, 843, 2.56, 0, 0.08, 13.73, 12
1.50, 50.38, 843, 2.56, 0, 0.10, 13.73, 10
1.63, 50.38, 843, 2.56, 0, 0.08, 13.73, 11
1.75, 50.38, 843, 2.56, 0, 0.08, 13.73, 10
1.88, 50.38, 843, 2.56, 0, 0.08, 13.73, 11
2.00, 50.38, 843, 2.56, 0, 0.10, 13.73, 10
2.13, 50.38, 843, 2.56, 0, 0.16, 13.73, 9
2.25, 50.38, 843, 2.56, 0, 0.23, 13.73, 9
2.38, 50.38, 843, 2.56, 0, 0.53, 13.73, 10
Picutes Link: http://www.mustangmods.com/data/71/idle.jpg
Notepad Link: http://benji99.homestead.com/files/Idle.txt
Next up: Cruising and WOT logs
Here is the WOT Log. Below you can also find a link to a picture as well as a txt file for easy viewing.
WOT LOG
Time........Hz.......RPM......IPW.Knock...o2....TPS....Timing
254.66, 233.03, 2406.25, 4.61, 0.00, 0.10, 22.75, 31.00
254.78, 239.33, 2406.25, 4.61, 0.00, 0.68, 22.75, 31.00
254.91, 233.03, 2375.00, 4.61, 0.00, 0.70, 22.75, 31.00
255.03, 239.33, 2375.00, 4.61, 0.00, 0.25, 34.12, 31.00
255.16, 251.92, 2406.25, 6.66, 0.00, 0.04, 71.37, 24.00
255.25, 421.97, 2375.00, 9.22, 0.00, 0.02, 98.82, 22.00
255.38, 421.97, 2375.00, 8.70, 0.00, 0.02, 100.00, 21.00
255.50, 440.86, 2406.25, 8.96, 0.00, 0.00, 100.00, 20.00
255.59, 447.16, 2406.25, 9.22, 0.00, 0.02, 100.00, 19.00
255.72, 453.46, 2406.25, 9.47, 0.00, 0.00, 100.00, 18.00
255.84, 472.35, 2375.00, 9.98, 0.00, 0.00, 100.00, 18.00
255.94, 484.95, 2437.50, 9.73, 0.00, 0.00, 100.00, 18.00
256.06, 484.95, 2406.25, 9.73, 0.00, 0.00, 100.00, 18.00
256.19, 484.95, 2406.25, 9.98, 0.00, 0.00, 100.00, 16.00
256.28, 529.04, 2437.50, 10.75, 0.00, 0.00, 100.00, 15.00
256.41, 529.04, 2375.00, 10.50, 0.00, 0.00, 100.00, 16.00
256.53, 510.14, 2406.25, 12.03, 0.00, 0.00, 100.00, 13.00
256.66, 566.82, 2406.25, 12.54, 0.00, 0.00, 100.00, 11.00
256.78, 610.91, 2437.50, 13.82, 0.00, 0.00, 100.00, 11.00
256.88, 636.10, 2437.50, 14.34, 0.00, 0.02, 100.00, 11.00
257.00, 636.10, 2468.75, 14.34, 0.00, 0.02, 100.00, 11.00
257.09, 636.10, 2437.50, 14.08, 0.00, 0.02, 100.00, 11.00
257.22, 642.40, 2437.50, 14.59, 0.00, 0.00, 100.00, 11.00
257.31, 648.70, 2406.25, 14.59, 0.00, 0.00, 100.00, 11.00
257.41, 648.70, 2406.25, 14.59, 0.00, 0.00, 100.00, 11.00
257.53, 661.29, 2437.50, 14.85, 0.00, 0.00, 100.00, 11.00
257.63, 667.59, 2437.50, 15.10, 0.00, 0.00, 100.00, 11.00
257.75, 667.59, 2437.50, 15.10, 0.00, 0.00, 100.00, 11.00
257.88, 680.19, 2468.75, 15.10, 0.00, 0.00, 100.00, 11.00
258.00, 686.49, 2468.75, 16.64, 0.00, 0.00, 100.00, 10.00
258.09, 787.25, 2468.75, 17.92, 0.00, 0.61, 100.00, 10.00
258.22, 793.55, 2437.50, 17.15, 0.00, 0.70, 100.00, 11.00
258.34, 692.78, 2500.00, 14.85, 0.00, 0.02, 100.00, 11.00
258.44, 673.89, 2500.00, 14.85, 0.00, 0.00, 100.00, 11.00
258.53, 680.19, 2468.75, 15.10, 0.00, 0.00, 100.00, 11.00
258.66, 686.49, 2468.75, 14.85, 0.00, 0.00, 100.00, 11.00
258.78, 680.19, 2437.50, 15.36, 0.00, 0.00, 100.00, 11.00
258.88, 705.38, 2468.75, 15.62, 0.00, 0.00, 100.00, 11.00
259.00, 655.00, 2468.75, 14.08, 0.00, 0.21, 100.00, 11.00
Picture Link: http://www.mustangmods.com/data/71/wot.jpg
Notepad Link: http://benji99.homestead.com/files/WOT.txt
Here is the Cruise Log. Below you can also find a link to a picture as well as a txt file for easy viewing.
CRUISE LOG
418.81, 138.56, 2625.00, 2.56, 0.00, 0.10, 19.61, 37.00
418.94, 138.56, 2593.75, 2.82, 0.00, 0.06, 19.22, 36.00
419.09, 138.56, 2593.75, 2.56, 0.00, 0.10, 19.22, 36.00
419.22, 138.56, 2593.75, 2.82, 0.00, 0.16, 19.22, 36.00
419.34, 132.26, 2593.75, 2.56, 0.00, 0.64, 19.22, 36.00
419.50, 132.26, 2625.00, 2.56, 0.00, 0.70, 19.22, 37.00
419.63, 132.26, 2593.75, 2.56, 0.00, 0.49, 19.22, 37.00
419.78, 132.26, 2593.75, 2.56, 0.00, 0.06, 19.22, 36.00
419.91, 132.26, 2593.75, 2.56, 0.00, 0.16, 19.22, 37.00
420.06, 132.26, 2625.00, 2.56, 0.00, 0.10, 19.22, 37.00
420.19, 132.26, 2593.75, 2.56, 0.00, 0.61, 19.22, 36.00
420.34, 132.26, 2593.75, 2.56, 0.00, 0.72, 19.22, 37.00
420.47, 132.26, 2593.75, 2.56, 0.00, 0.57, 19.22, 36.00
420.59, 132.26, 2625.00, 2.56, 0.00, 0.31, 19.22, 36.00
420.75, 132.26, 2625.00, 2.56, 0.00, 0.08, 19.22, 37.00
420.88, 125.96, 2593.75, 2.56, 0.00, 0.10, 19.22, 37.00
421.00, 132.26, 2593.75, 2.82, 0.00, 0.21, 19.22, 36.00
421.16, 132.26, 2593.75, 2.56, 0.00, 0.70, 19.22, 36.00
421.28, 132.26, 2593.75, 2.56, 0.00, 0.72, 19.22, 36.00
421.44, 132.26, 2625.00, 2.56, 0.00, 0.29, 19.22, 36.00
421.56, 132.26, 2593.75, 2.56, 0.00, 0.08, 19.22, 36.00
421.72, 132.26, 2593.75, 2.82, 0.00, 0.18, 19.22, 36.00
421.84, 132.26, 2593.75, 2.82, 0.00, 0.63, 19.22, 36.00
421.97, 138.56, 2562.50, 2.56, 0.00, 0.68, 19.22, 36.00
422.13, 132.26, 2593.75, 2.56, 0.00, 0.68, 19.22, 37.00
422.25, 132.26, 2593.75, 2.56, 0.00, 0.06, 19.22, 36.00
422.41, 132.26, 2593.75, 2.82, 0.00, 0.08, 19.22, 36.00
422.53, 138.56, 2562.50, 2.82, 0.00, 0.25, 19.22, 36.00
422.66, 138.56, 2593.75, 2.82, 0.00, 0.70, 19.22, 36.00
422.81, 138.56, 2593.75, 2.56, 0.00, 0.66, 19.22, 36.00
422.94, 132.26, 2562.50, 2.56, 0.00, 0.08, 19.22, 36.00
423.09, 132.26, 2593.75, 2.82, 0.00, 0.06, 19.22, 36.00
423.22, 132.26, 2562.50, 2.82, 0.00, 0.18, 19.22, 36.00
423.34, 138.56, 2593.75, 2.82, 0.00, 0.61, 19.22, 36.00
423.47, 138.56, 2562.50, 2.82, 0.00, 0.72, 19.22, 36.00
423.63, 138.56, 2562.50, 2.82, 0.00, 0.70, 19.61, 36.00
423.75, 138.56, 2562.50, 2.82, 0.00, 0.41, 19.61, 36.00
423.91, 138.56, 2562.50, 2.82, 0.00, 0.10, 19.61, 36.00
424.03, 138.56, 2562.50, 2.82, 0.00, 0.16, 19.61, 36.00
424.16, 138.56, 2593.75, 2.82, 0.00, 0.66, 19.61, 36.00
424.31, 144.85, 2562.50, 2.82, 0.00, 0.70, 19.61, 36.00
424.44, 138.56, 2562.50, 2.82, 0.00, 0.53, 19.61, 36.00
424.59, 144.85, 2593.75, 2.82, 0.00, 0.08, 20.00, 36.00
424.72, 144.85, 2593.75, 2.82, 0.00, 0.12, 20.00, 36.00
424.84, 144.85, 2562.50, 3.07, 0.00, 0.57, 20.00, 36.00
424.97, 144.85, 2562.50, 2.82, 0.00, 0.68, 20.00, 36.00
425.13, 144.85, 2562.50, 2.82, 0.00, 0.55, 20.00, 36.00
425.25, 151.15, 2593.75, 3.07, 0.00, 0.10, 20.00, 36.00
425.41, 151.15, 2562.50, 2.82, 0.00, 0.63, 20.00, 36.00
425.53, 151.15, 2593.75, 2.82, 0.00, 0.55, 20.00, 36.00
425.66, 151.15, 2593.75, 3.07, 0.00, 0.43, 20.00, 36.00
425.81, 151.15, 2562.50, 3.07, 0.00, 0.29, 20.00, 36.00
425.94, 151.15, 2562.50, 3.07, 0.00, 0.64, 20.00, 36.00
426.09, 151.15, 2562.50, 3.07, 0.00, 0.68, 20.39, 36.00
426.22, 151.15, 2562.50, 3.07, 0.00, 0.33, 20.39, 36.00
426.38, 157.45, 2562.50, 3.07, 0.00, 0.08, 20.39, 36.00
426.53, 157.45, 2562.50, 3.07, 0.00, 0.53, 20.39, 36.00
426.66, 157.45, 2562.50, 3.07, 0.00, 0.68, 20.39, 36.00
426.78, 157.45, 2562.50, 3.07, 0.00, 0.39, 20.39, 36.00
426.94, 157.45, 2593.75, 3.07, 0.00, 0.10, 20.39, 36.00
427.06, 157.45, 2562.50, 3.07, 0.00, 0.23, 20.39, 36.00
427.22, 157.45, 2562.50, 3.07, 0.00, 0.64, 20.39, 36.00
427.34, 157.45, 2562.50, 3.07, 0.00, 0.21, 20.39, 36.00
427.47, 157.45, 2562.50, 3.33, 0.00, 0.23, 20.39, 36.00
427.63, 157.45, 2562.50, 3.07, 0.00, 0.68, 20.39, 36.00
427.75, 157.45, 2562.50, 3.07, 0.00, 0.12, 20.78, 36.00
427.88, 157.45, 2562.50, 3.33, 0.00, 0.12, 20.78, 36.00
428.00, 163.75, 2562.50, 3.33, 0.00, 0.10, 21.18, 35.00
428.16, 170.05, 2562.50, 3.33, 0.00, 0.06, 21.57, 35.00
428.28, 176.35, 2562.50, 3.58, 0.00, 0.04, 22.75, 35.00
428.44, 195.24, 2562.50, 4.10, 0.00, 0.06, 22.75, 34.00
428.56, 207.84, 2562.50, 4.35, 0.00, 0.10, 23.14, 33.00
428.72, 214.13, 2562.50, 4.35, 0.00, 0.18, 23.14, 33.00
428.84, 214.13, 2562.50, 4.35, 0.00, 0.70, 23.14, 33.00
428.97, 220.43, 2562.50, 4.35, 0.00, 0.66, 23.14, 33.00
429.13, 220.43, 2562.50, 4.10, 0.00, 0.47, 23.14, 33.00
429.25, 214.13, 2562.50, 4.35, 0.00, 0.08, 23.14, 33.00
429.41, 214.13, 2593.75, 4.35, 0.00, 0.14, 23.14, 33.00
429.56, 220.43, 2593.75, 4.61, 0.00, 0.66, 23.14, 33.00
429.69, 220.43, 2562.50, 4.35, 0.00, 0.74, 22.75, 33.00
429.81, 214.13, 2562.50, 4.10, 0.00, 0.70, 22.75, 33.00
429.97, 214.13, 2562.50, 4.10, 0.00, 0.35, 22.75, 34.00
430.09, 214.13, 2593.75, 4.10, 0.00, 0.06, 22.35, 34.00
430.25, 214.13, 2562.50, 4.35, 0.00, 0.61, 22.35, 34.00
430.38, 214.13, 2593.75, 4.10, 0.00, 0.74, 21.96, 34.00
430.50, 207.84, 2593.75, 4.10, 0.00, 0.76, 21.96, 34.00
430.63, 207.84, 2593.75, 3.84, 0.00, 0.74, 21.96, 34.00
430.75, 201.54, 2562.50, 3.84, 0.00, 0.66, 21.96, 34.00
430.88, 201.54, 2593.75, 3.84, 0.00, 0.33, 21.96, 34.00
431.03, 201.54, 2562.50, 3.84, 0.00, 0.20, 21.96, 34.00
431.16, 195.24, 2562.50, 3.84, 0.00, 0.66, 21.96, 35.00
431.28, 195.24, 2562.50, 3.84, 0.00, 0.43, 21.96, 34.00
431.44, 195.24, 2593.75, 3.84, 0.00, 0.51, 21.57, 34.00
431.56, 195.24, 2593.75, 3.84, 0.00, 0.68, 21.96, 35.00
431.69, 195.24, 2562.50, 3.58, 0.00, 0.47, 21.96, 35.00
Picture Link: http://www.mustangmods.com/data/71/cruise.jpg
Notepad Link: http://benji99.homestead.com/files/cruise.txt
One more and that's it for now.
Here's a link to the complete TMO Log. So if you have TMO ... you can view this: http://benji99.homestead.com/files/BadTestLog.tlg
You should also check out this huge log pic: http://benji99.homestead.com/files/LongLog.jpg
Or download the complete log as an excel spreadsheet: http://benji99.homestead.com/files/BadTestLog.xls
LOL, Never buy electrical parts from CSK auto, I know, I work for them. I too put the Borg Warner O2 sensor in and it died in three days, so I bought one from the dealer, and haven't had any problems. Good luck.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
