Nitrous Kit Install Help
ECLIPSEGST25 said:
Well I Ran Hte Ss Line For The Bottle. So I Need Help With The Wireing And The Fuel Setup. It;s A Nos Wet Kit With Purge
Wow it has been a long time since I have wired up a nitrous system.
Steps:
1) Gather all parts needed. (solenoids, toggles, relays, and wires.)
2) Disconnect battery ground
3) Locate a spot to mount the solenoids, mount and ground them
4) Tie both power supplies together and run them to the relay.
5)Locate power source
6) Run a wire from the power source to the arming switch ( 1 way toggle)
7) Run a wire the signal wire from the toggle to the relay ( this will be the power supply for the relay)
8) Locate a location to mount the firing switch (either WOT switch or momentary push button toggle) This will require a seperate power source.
9) Run the signal wire from the firing switch to the relay (this will be the signal wire)
10) Run the output power wire from the relay to the hot wires for the solenoids
Now when you turn on the arming switch power will reach your relay, when the relay receives a signal (from the firing switch) it will send that power to the solenoids and fire them.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
