Need some wire clarification on greddy TT install...
crash89
3,543
195
Mar 5, 2008
Punta Gorda, Florida
Hey guys im trying to install my greddy turbo timer (dont have a manual) in my 99 gst, and I just need some clarification on which wires to tap into. Im trying to hardwire this into the system because i dont have the harness adaptor.
[/URL]
[/IMG]
I know red=12v constant, black= grnd, blue= accessory, green= switch on. the two little ones are for the speed sensor and e-brake. and not sure what the last one is.
[/URL]
[/IMG]
If im correct I should be able to tap the RED into the White, BLUE into Blue w/ black, and GREEN into Blue right?
[/URL]
[/IMG]
Idont want to just start cutting and trying different wires in the ignition harness. Any help is appriciated guy. Thanks
go to there web site and down load the manual or let me know if you cant i can fax it to you
I checked out the manual for the TT but it still doesnt state what wires are what in my cars ignition harness. Thats all I need to know, exactly which wires I should splice into. I have the general idea but I dont want to go just cutting wires and have it not work. ya know?
Alright guys, I found the plug and play harness for the TT. So I went and followd the instructions in the greddy manual, made a good ground, turned the key and nothing. The timer didnt turn on, tried pushin the power button still nothing (the manual said it could be off). I dont have the 4 prong clip to 3 prong. Just the harness, so I cut the clip off and put some crimps on the wire, and plugged them to the appliciable wires on the TT. Now on the starter switch there is a black w/ red wire that is labled "st" and on the harness there is a white wire that connects to that one. Should I splice the Green and White wires together?
nevermind the white and blue wires. The one labeld is the wire Im talking about. Black w/ red
[/URL][/IMG]
Here is the greddy harness adaptor. You can see the white wire.
[/URL][/IMG]
