my car won't start!!
jackazz
Feb 22, 2004
East Cleveland, Ohio
I have a 95 talon tsi awd 5 speed. Pretty much stock.
Just replaced the timing belt and before I put all the accessories back on I want to make sure this is right. All the car will do is crank and crank. It will not start. I know that I am getting fuel because I can smell it and hear the pump running. I also know that spark is fine because I tested both coil packs and installed new plugs. There is currently no exhaust system on beyond the o2 housing. What should I do next?
Thanks to anyone who can provide some guidance on this issue.
Mark
pull all the plugs out attach the spark plug wires and have someone try to crank it. if you r getting spark on coil 2-3 and not on 4-1 than join myself and four other people i know. i took my car to the dealership, once i hear something i will let u know. that is if it is the same prob.
sonny
Thanks for the good suggestion. Unfortunately, I already tried that and all four are producing spark. Thanks and good luck to you.
