LubeGard
96boosted
Apr 5, 2003
From all the threads regarding ATF, it's always recommended that when using synthetic ATF or Dexron/Mercon ATF, add a bottle of the Black LubeGard. The direction says 1 oz per quart. The box also said over using LubeGard causes slippage. The capacity of the tranny is only 7.1qt, and the drain plug only drains 4qt.
What I need to know is:
A. Do I dump the whole bottle of LubeGard in there?
It's 10oz/per bottle, which would mean I'm using 140% of the recommended amount.
(10oz/7.1qt vs 7.1oz/7.1qt recommended)
B. After I've added LubeGard, on the next ATF change, because I can only drain 4 qts out of the 7.1. Do I still add another 10oz? Draining 4/7.1qt means there are still 4.4oz of the old LubeGard in the tranny mixed with old ATF. Adding another 10oz would mean I have 14.4oz of LubeGard with only 7.1qt of ATF. that's over 200% of the recommended amount.
Right now I only added 4oz of LubeGard in there after I've drained 4qts of ATF. I don't know if I need more.
-96boosted
-96boosted
The capacity of your trans is more like 9 or 10 quarts, not 7.1.
Put in the whole bottle now and half a bottle on subsequent fluid changes.
-John
Thanks for the reply John. I opened the drian plug on both the pan and differential. But all I can get out is 4qts... The fluid looked burnt so I drove it with 4 new qts of fluid, then drained it again and adding 4 more qts. Besides having to take it to a tranny shop to have them flush the system, what is the best way to get rid of the burnt fluid? Run the car in neutral while the drain plug is out?
-96boosted
