Low idle and sputters alot
1995 brian
233
Dec 16, 2011
Leadville, Colorado
So my 97 gsx is having a very low idle issue and it sputters alot during idle. Threw a check engine and 5 codes came up.
P0110- iat sensor circuit malfunction
P0100- maf or vaf a circuit malfunction
P0325- knock sensor 1 circuit malfunction
P0105- map/BARO circuit malfunction
P0510- closed throttle position switch.
Any ideas where to start.?
So i disconected the isc while it was idling and it didnt change the low idle or the studdering also i notice the turbo has quite some shaft play in and out and it smokes white from the tail pipe.
It runs alright and it smokes when you press the gas. Could it be a blown turbo? Another thing is all these issues started right after timing job. But all marks were double checked.
When i disconect the maf the idle gets worse so i dont think its the maf because i replaced it with another one i had.
So i went ahead and pulled everything apart to check timing and it was dead on im lost idk what to check.
