Spyder installing a Aftermarket clutch on your 4g64 spyder
I've installed a ACT clutch, flywheel, and 2600lb. pressure plate on my 99 Spyder GS. This, of course, is made for the 2G Eclipse GS-T with the 7 bolt crank. It all bolts right up with NO MODS!
You must adjust the master cylinder clutch pedal rod for more travel during engaging and disengaging though. It's very simple! under your dash unlock the the 13MM nut from the clutch rod while holding the clutch master cylinder rod with a 1/4" in the slots just behind the nut. Turn the rod out 3 full turns or 1/2". You can go out a full inch, but engagement at the 1/2" place disengagement and engagement at about half pedal with 1/2 pedal to floor being soft enough to hold your car on a hill at a light without the brake.
Novice clutch users know what I mean! This setup is great and grabs very well, but I do recommend replacing the clutch master cylinder while you are replacing the clutch b/c a worn clutch cylinder will wear out your clutch quicker!
Good Luck and really look around for parts for this car. GS-T and GS-X Eclipse parts bolt right up on this car!
  • Wanted 2g 1995 Eclipse GS-T Driver door cap wanted
    I'm looking for a 1995 GS-T driver side door cap or even a complete door with the proper door cap.
    • loco4G63
  • Wanted 1g MB668570 front ABS Ring for 1992 D27A
    I would really need front ABS rotors for my 1992 D27A eclipse with AWD. Would really appreciate...
    • Gurkigg
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
