Idle Problem
grimyth
34
Oct 19, 2004
Shreveport, Louisiana
I just recently installed the AEM EMS. And we got it to start, but everytime i start it it revs at about 2k then slowly creeps to 3k and jsut stays ther at idle... i didn't touch the TPS and i checked for Vacuum leaks , infact ireran all the vacuum hoses and it still does the same thing. we messed around with the EMS and when we tried lowering the idle it actually increased ........ If anyone had any ideas that would be awesome and any help would be much appreciated
Russell
not trying to be wise.....try decreasing the idle......maybe you have it wired backwards
nah we did....when we tried to lower it the idle went up...when we tried to raise it nothing happend
is your idle switch working? (the switch on the TB) that tells the ecu the throttle is closed? Is the throttle body grounded properly? Tried adjusting the biss screw i assume?
yeah we adjusted the screw all the way down didnt do anything....and the iac plugged or unplugged did the same thing
