HKS Blowoff Valve - Which one?
Outrun Talon
78
Aug 1, 2011
Floyd, Virginia
I have an opportunity to get a HKS Super SQV3 for around $110 or so plus a little for shipping. HKS just came out with the SQV4 to "thwart off the counterfeiters". According to This Page the changes are only cosmetic. Can anyone verify this?
I ask because a SQV4 is like $400 and the SQV3 is $110. If the changes are in fact cosmetic to try and curb the counterfeiters a bit, I don't see the reason why I should spend an extra $300 for the latest model. I'm just wanting to make sure the SQV4 isn't way better or something and that the SQV3 that I am looking at is just as good as the new cosmetically different model.
right from hksusa.com
"In 1994, HKS introduced the first Sequential Blow-Off Valve featuring a unique, pull-type, sequential valve structure and a differential pressure control system. This advanced pull-type relief system allowed for stable operating ranges from low to high boost pressures. Since imitation is the highest form of flattery, HKS has once again redesigned the physical aspects of the Super Sequential Blow Off Valve to thwart off the counterfeiters.
Reliable functionality of the Super SQV 4 is unchanged and utilizes the same mounting flanges as all previous generation SSQVs. This assures compatibility with all optional HKS SSQV inserts, recirculation fittings and recirculation kits.
Super SQV 4 features include a nickel-plated, die-cast metal secondary valve, which is swaged to the primary valve, a stainless steel C-Clip and spring to increase sealing and durability."
Seems to be physical only
I figured as much, I just wanted to get a 2nd opinion to make sure. Thank you!
Well, said.. This guy does his homework!
I ended up buying a HKS SQV3 for around $129 shipped to my door. Saved myself quite a bit, I can't wait to install it!
