hesitation when accelerating
josherino
148
Sep 18, 2004
Ft Collins, Colorado
I have a 90 gsx that hesitates/jolts when accelerating, it is especially noticible around the 2000 to 3000 rpm band and also when the car is not completely warmed up. what is causing this hesitation? could it be a bad fuel pump?
how can you tell the difference between misfiring and a slight fuel cut b/c I know my stock fuel pump is almost dead?
you also might want to do a leak check. i had a real bad studder and did a leak check and solved most of my problems. also check your plugs and wires. good luck.
