Front Solid Subframe bushings/ from black_gst
I purchased these solid aluminum bushings from black_gst with the purpose of replacing the vehicle's rubber bushings on the front subframe.
I received 6 bushings & 6 hat bushings for a total of 12 pcs.
Once I unboxed them, I measured the outside diameter of all the bushings and they measured as so:
small bushing: 1.334
medium bushing: 1.778
large bushing: 1.998
I then measured the Inner Diameter of the subframe bushing holes:
small hole: 1.334*
medium hole: 1.776*
large hole: 1.997*
*Every subframe may be slightly different but this review is based off my components.
You will need a press to install all of them, allow me to tell you that they all fit pretty snug and I had no problem as far as the I.D being smaller then the bushing's O.D.
all my studs & bolts lined up perfectly and installation was a breeze. I recommend this product if you are up for the task. please review the pictures I posted.
Pm me with any additional comments you think I should add to make this review better.
EDIT: I have made a "how-to" on these bushings found here: http://www.dsmtuners.com/forums/art...ow-install-solid-bushings-front-subframe.html
