Formula for hz to power or cfm?
dsm10sec
Banned Member
145
Oct 14, 2004
Minneapolis, Minnesota
Hey guys whats the formula for the hz the 1g ecu sees to cfm or power (asuming it's a 12:1 air:fuel)??
1606hz, WOT, 20 deg timing, .88 on o2 at 6375 rpm with my TD05H/20g in 2nd gear w/ 100 octane. BTW I'm at 93% duty cycle on 750ccs w/ 255lph pump.
1606 HZ? Thats as high as the pocketlogger will show (highest the stock ecu shows)
(Ill assume thats where you got your numbers from.)
An SAFC2 will show the real numbers.
Going by what you quoted, Im sure you're over that number :thumb:
My 14b @ 18-20 psi shows around 2100 HZ, for comparisons.
From the last time I asked this question, a rough guess for HP to HZ was 2000HZ = 300HP. That was doing some funky math and some guesswork. I wouldnt take that number to the bank.
That thread was on DSMtalk awhile ago, so the info is gone.
That sucks... I only have an SAFC not v2... Isn't there someway I can hook up a voltmeter or somethin to find out what it's really at? I have a MAF-T with 3" MAF in blow thru if that makes any difference.
Forgot, my car's a track car... I'll make a run tonight and see what it is.
