First log on stock car. Is this normal?
phunny
3,155
22
Feb 1, 2005
Pittsboro, Indiana
This is on my 1997 TSI AWD AUTO completely stock except for the BOV. It stutters the whole way until redline. Any suggestions? I'm guessing boost leak?
RPM Timing O2
2460 14 0.9
3040 12 0.9
3592 7 0.92
3816 3 0.94
3992 3 0.94
4168 7 0.94
4312 7 0.94
4496 7 0.94
4648 7 0.94
4816 6 0.94
4916 8 0.94
5000 10 0.92
5132 11 0.92
5228 11 0.92
5332 11 0.92
5452 12 0.92
5588 12 0.92
5728 13 0.92
5860 14 0.92
6092 17 0.92
6220 18 0.92
6324 18 0.92
6440 19 0.92
Timing and O2 look good for a stock car. I would pull the plugs and have a look at them. If they're tan all the way across, you're fine, very white is lean and black is rich. Now since you still have the factory ECU with the factory A/F, you're probably a bit rich. Running a boost leak test would be a great idea anyway since it'll help performance.
As far as your misfire and stutter, I would look to spark issues first. Drop in a set of NGK BPR6ES gapped to .028 (Autolite 63's work too) and change your plug wires. Most misfire issues are cured with simple fixes.
Let us know if that does it,
Andy
Once again, Andy is absolutely correct. :thumb:
One other thing to check would be fuel delivery. I had a pretty good stutter last year and it turned out that the problem was with my fuel filter. Man, you should have seen the crap that was in that thing. OMG
Nathan, has a great point. I focused on spark (lack of coffee again) but fuel is critical. If the filter hasn't been replaced in the last few years, or if you're not sure when it was last changed, swap it out.
Nice catch bro!
Andy
phunny said:
680CC injectors, fuel pump, gauges, and i'm looking for a safc right now.
Anything over 650's are tough to tune on an AFC due to the airflow correction required. If those are PTE's, they actually flow at 650cc since PTE rates them at higher fuel pressure. If you run into a tuning snag with the AFC, Nathan (spyderturbo007) is your new best friend since he's very well versed at getting the most out of it safely.
When I bought the car the guy told me they were 680's and he thought it was a 255 fuel pump, but i'm not sure if i can tell for sure. I remember the injectors had a green tip if that means anything. Thanks for the fuel filter idea, I never even thought :(
I was just searching around and remembered another question. I just replaced my alternator which had died and all three lights were on as usual. And now my brake light stays on and i'm pulling code p1500 from my logger. I'm guessing maybe the 2 are related and noone seems to know how to fix p1500.
charlie
