Engine Build Part 3: Oil Squirter Connundrum
kwbunn
54
Apr 20, 2007
Virginia Beach, Virginia
Well, turns out that Jackson can't put oil squriters into the block. If you look at the block and the closeup, you'll see that there's a mount for the squirters in every cylinder except #4. If you're having a difficult time, look closely for the little tabs with holes in the block. Jackson says instead of putting the oilers in, they're gong to machine the rods to provide essentially the same effect. There are other 4G64's out there running *without* oilers, so I suppose I'll be okay. It's not like I'm going for 650WHP anyway.
